get a genuine part!,i guess your talking about the heavy washer behind the entire assembly rides against the shaft?you need part # 90455-374-000,if you mean the thin shim inside the basket behind the circlip theres a coupla sizes depending on the end float you need,i see your in Australia where bouts?
