Author Topic: CB750K1 Master cylinder and switches paint?  (Read 715 times)
Offline scrambler
« on: November 20, 2019, 01:57:33 PM »
Hi All,
I`m preparing the parts to get powder coated. I`m not sure what to do to the master cylinder and the aluminum cases for the controls. They have this weird color somewhere in between black and purple, and I can`t really tell what the original color was. I`m looking for something close to the original.  Also, I`m not sure if I should try powder coating on these, bc last time on another bike they ended up being not too nice due to outgassing. Can somebody chime in if done these parts? Thanks!
Offline Can550
Re: CB750K1 Master cylinder and switches paint?
« Reply #1 on: November 20, 2019, 02:10:21 PM »
I got switch housings powder coated
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: November 20, 2019, 02:31:46 PM »
I use a gloss black rattle can paint from a local auto supply store. It’s made/sold for painting brake calipers. Seems to hold up well and easily reapplied if brake fluid get’s on it. I tried powder coating and it looks too thick. Not sure about the switches. I usually apply “Back to Black” (detailing spray for black bumpers and trim) or replace.
« Last Edit: November 20, 2019, 04:35:30 PM by BenelliSEI »
« Reply #3 on: November 20, 2019, 02:43:58 PM »
Anodize
Offline scrambler
« Reply #4 on: November 20, 2019, 05:43:51 PM »
Thanks for all the comments! Probably the best way is anodizing, actually the original coating seems to be anodized indeed, as Mthf*r suggested. Did you get it done by a shop or you DIY-d it?
Offline tlbranth
« Reply #5 on: November 20, 2019, 07:28:52 PM »
The anodized looks like #$%* after a while, which is what you're seeing. Paint looks much better.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline scrambler
« Reply #6 on: November 21, 2019, 11:45:35 AM »
So, I assume originally they were black.
Offline tlbranth
« Reply #7 on: November 21, 2019, 05:10:47 PM »
Yes they were. The downside of paint is that brake fluid can mess it up. If you don't want to go the full Monty with 2 part paint, black bumper paint is easy to use and does a decent job.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
