Author Topic: 750 K0 electrical demons!!  (Read 1313 times)
Offline Tews19
  • I am no
« on: November 19, 2019, 07:01:26 PM »
Well today I tried to hunt down my electrical gremlin on my K0. I have 12.74V to everything upto my ignition switch. Then when I try to see where a break is, nothing. It's all testing out properly. I used my new repop Yamiya controls and it worked fine. Then a pop.... Sounded like the fuse blew but it did not...
I grabbed the old control and nothing, no power at all still.
I pulled the ignition switch itself, tested for Ohms and it came back functioning properly.
Any help would be greatly appreciated.
1970 Honda CB750 survivor.
Offline Spanner 1
Re: 750 K0 electrical demons!!
« Reply #1 on: November 19, 2019, 07:15:42 PM »
With the Red +probe of your meter on the ign. switch Red and the Black meter lead on the battery Ground you read 12+V right ? With the headlight turned on first, what happens to that voltage when you turn the ign. 'on' ?
« Last Edit: November 19, 2019, 07:18:28 PM by Spanner 1 »
Offline Tews19
  • I am no
« Reply #2 on: November 19, 2019, 07:35:52 PM »
Yep, just as you stated Spanner that is correct. I have no power at all after the ignition switch itself. My gauges won't light up so i havent tried w the headlight. Also the horn amd turn signals do not work now
Offline Spanner 1
« Reply #3 on: November 19, 2019, 07:56:49 PM »
Bad ign. switch or ( my bet ) loose and corroded main fuse clips. They must be tight and grip the fuse to where you can't pull the fuse with your fingers !.. also must be completely shiny for electrical connection  ;)
« Reply #4 on: November 19, 2019, 08:35:45 PM »
 You can plug a blade fuse onto the wires on a k0 fuse panel. Try that.
Offline Tews19
  • I am no
« Reply #5 on: November 19, 2019, 08:37:36 PM »
I literally swapped out a fuse block from a 69 750 and it works perfect. Tried  it again and samerhing. Nothing. I put my fuse block on the 69, full power there.
Offline pjlogue
« Reply #6 on: November 20, 2019, 04:49:52 AM »
Water ingress into the ignition switch can cause corrosion which in turn can cause heating which can melt the solder where the wires connect to the switch.  Take the switch apart and clean any crud out and remove any oxidation from the contacts inside the switch.  To open the switch you need to bent the crimp dimples out.  Be careful not to lose springs, BB's when it comes apart.
If you have corrosion there you will have it in other areas of the harness connections.  The output from the alternator is a particular concern.  A lot of bikes have the connectors over heated from corrosion on the terminals.
-P.
Offline Tews19
  • I am no
« Reply #7 on: November 20, 2019, 07:13:35 PM »
I swapped the fuse single box from a 69 750, it works on the 69. That's not the issue. It's freaking mind boggling.
Offline Tews19
  • I am no
« Reply #8 on: November 20, 2019, 07:15:26 PM »
-P.
P, on my stator, i had to repair one of the three wires.  Are you saying my stator could be the culprit for absolutely no power after the ignition? How can i test my stator?
« Reply #9 on: November 20, 2019, 07:35:28 PM »
If you have 12v at the red switch wire but 0 on the black with switch turned on switch is bad. Temporarily connect red to black in loom connector block with a jumper wire if all works proves switch duff
Offline Spanner 1
« Reply #10 on: November 20, 2019, 07:39:46 PM »
^ Brian+1...….. you can make a jumper wire from the battery + to the Black wire on the regulator ( has B/G/W connections ) right below the battery = bypassing the ign. switch and saves you from removing the tank to get to the ign. switch connector  ;)
Offline Tews19
  • I am no
« Reply #11 on: November 20, 2019, 07:40:34 PM »
I removed the brown encasing on the switch and also on harness. I trimmed the M and F ends off and have exposed wires. I made jumpers from red to red off the ignition  and the black, brown and brown/white wires. 12.74V to everything.
Offline Spanner 1
« Reply #12 on: November 20, 2019, 07:54:50 PM »
And what happened ?
Does the bike start and all the lights work ?
« Last Edit: November 20, 2019, 07:58:28 PM by Spanner 1 »
Offline Tews19
  • I am no
« Reply #13 on: November 20, 2019, 07:56:56 PM »
12.7v to red to red, black to black, brown to brown and b/w to B/w.
Offline Spanner 1
« Reply #14 on: November 20, 2019, 08:00:11 PM »
Offline Tews19
  • I am no
« Reply #15 on: November 20, 2019, 08:04:05 PM »
And what happened ?
Nothing, no power, no lights. I can't even jump the solenoid
« Last Edit: November 21, 2019, 12:32:58 AM by Tews19 »
Offline Spanner 1
« Reply #16 on: November 21, 2019, 08:44:23 AM »
If the starter wont turn when you 'jump' the big terminals on the solenoid, then I'd be having a close look at the battery terminals. Need to be tight and the surface of the terminals must be shiny bright.  Also the top of the battery's terminals shiny. Good luck !
Offline Bankerdanny
  • Endeavor to persevere
« Reply #17 on: November 21, 2019, 09:52:30 AM »
If bridging the solenoid terminals does get it to turn over then I would check the ground connection and the connection from the positive terminal to the solenoid.
« Reply #18 on: November 22, 2019, 06:18:47 PM »
The K0 has a bullet-contact type main plug on the power switch, and those contacts are only rated to 15 amps. After 50 years, they won't carry 10 amps, as they were not even plated with zinc(!). Unplug the main switch and check the condition of the contacts: they are likely burnt. I have the K2 with the same switch, now the 4th one. I finally changed it to be the later version, with the blade contacts instead of the bullets, and since they are rated to 17 amps, it has not had any more trouble in the last 10 years from it. If you need the mating connector to add to the harness, go to www.vintageconnections.com and get the 4-blade connector set (about $5) and their excellent crimpers. I also add a dab of solder to that joint, as the solder improves the conductivity about 15% more.
Offline Tews19
  • I am no
« Reply #19 on: November 23, 2019, 06:54:35 AM »
Jumping did nothing unfortunately Dan.
Offline Tews19
  • I am no
« Reply #20 on: November 23, 2019, 06:55:39 AM »
I bought the their kit w the crimper tool. Excellent stuff from the company and I highly recommend them. Excellent customer service too.
