Author Topic: Sprocket set on k7 is 41/15 with stock 630 chain. Need a new chain for next season, should I upgrade  (Read 3705 times)
Offline Pielz
Curious about what would really make a difference. My sprocket set looks great. There's not a noticeable amount of wear on the teeth so I don't think they really NEED replaced. I'm wondering though if I should go with a 530 chain as I've heard good things about their strength and benefits. Any opinions? I've seen threads about this but none on my model with the smaller sprocket sets. I wouldn't mind a little snappier low-end power as I'm not going to be using the upper limits of this thing's speed.
Offline slikwilli420
  • Master of Disaster
Modern 530 chains are found on all of the most powerful bikes put on the road today. A 530 kit with aluminum rear sprocket will reduce overall weight of that system considerably and will likely cost less for better quality than finding 630 components. If its time to change, there is absolutely no downside to going 530.
Offline Pielz
Awesome good to know! Is there a site that sells kits for our bikes that have everything? Or should I just verify fitment and get things separately? I'm making a little list of things I need to get in the future before it warms up again
Offline mrbreeze
  • Not your average
Another reason to change over to 530 is the availability of 630 components on the road. Roughly 10 years ago while doing the SOHC rally, a member that we were riding with encountered a stretched out chain that couldn't wait to be replaced when we got back home. After trying a handful of local shops to no avail, we found a 630 chain but it was roughly 50 miles out of our way to go get it. Not that we minded the extra riding we got in to go fetch the new chain it still could have cost a lot of headaches if the chain wasn't available. If I remember correctly all of the other shops had the 530 in stock.
MEMBER # 257
Offline Pielz
Wow that's a really great point. I hadn't actually thought of that. Btw how much do you typically spend on a chain? I've heard people talking about a few different brands and o ring or x ring. Not sure what to get!
Offline pjlogue
When I restored my '76 750 I went with a 530 set up.  I had looked for a 630 set up like I had but I could not find the  sprocket combos I wanted in that size so I went with the 530.
-P.
-P.
Hmm- no 630's in 1976 on either the K's or F's.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
-P.
that threw me for a loop too.
any recommendation on the aluminum rear sprocket?  seems like a soft metal to me for a sprocket.
cb750 k6 - ugly
Offline Pielz
So I'm searching the internet and I can only find 15 tooth or 14 tooth gears in 630 and 17 tooth and 18t in 530. In order to get the final drive ratio that's higher than my current id have to get like 17/51 and I definitely can't find rear sprockets with that many teeth. I may get a 14/43 or 15/46 and stay with 630. As much as I'd like a 530 lighter chain I can't seem to find what I need unless I'm just looking in the wrong place
« Last Edit: November 20, 2019, 06:50:01 pm by Pielz »
Offline Dolomite
  • I'm 40% Dolomite.
Cyclex sells the offset from sprocket for the 530 chain and I got my rear from JT. I'm running a JT 530  Z3 x ring chain. Working great so far.
Offline Pielz
So is the offset front sprocket for only certain bikes or is it offset to accommodate the smaller chain? I saw that but was nervous about it because I hadn't heard anyone mention those. what teeth #s are you using? What's your final drive ratio? Also what model bike?
I was hoping to bump my ratio up to 3 from the 2.7 it is for a little boost but I'm not sure what all is available.
« Last Edit: November 20, 2019, 09:10:00 pm by Pielz »
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
Defiantly do the small chain conversion. Less rotating mass, less unsprung weight, a tad more power, and mpg. No negitive.
Offline pjlogue
-P.
I had put the 630 on in 1977 or 78.  When I went to the 630 chain I put  JT Aluminum sprocket on the rear.  I think I had a 38 tooth rear (maybe 42) sprocket and 15 T front.  The diamond chain I had was a plain chain but very good quality and had very little power loss though it.  I was skeptical of the Aluminum rear sprocket but it did hold up well and because it was soft the road grit didn't chew up the chain.  I did take care of the chain though with regular cleaning and lubing.
-P.
A number of places sell a nice 530 aluminum sprocket for our bikes. I run 520 on my race bike so I won't be much help there. I do run a DID X-ring chain though and it was under $70. Should last thousands of miles with little maintenance.
Offline Dolomite
  • I'm 40% Dolomite.
I am at work right now but I am trying to find those numbers for you. I believe i stuck with the stock number of teeth though so as to not change anything but the chain. The front offset if i remember correctly is for running the 530 on pre 77 motors because they had the spacer as part of the sprocket while the 77/78 had the proper offset machined into the spline. If someone could confirm or deny that?
Offline maxheadflow
I used a 79 cb650 front sprocket on my 78 CB750.  It fit perfect.   Rear sprocket only needs to be flat.
Offline Pielz
Is it offset? And are you using 530 or 630 chain?
Offline maxheadflow
The back side is flat, no offset. It was recommended here.
I used a PBI Steel Front Sprocket 15T 348-15 off of ebay but you can get other teeth counts.
Offline Tracksnblades1
Silk,
Have you ran an aluminum sprocket on yours for any length....
I've got a 01 CR500R with expensive 48t 520 aluminum sprocket on back with a rototiller knobby.
The Regina 520 chain (huge overkill never needs adjusted) will lay the teeth forward in no time...
Worst thing about CR500, only 5 gears....Best thing about CR500, what ever gear your in, that's the right gear...😎
Age Quod Agis
Silk,
I roadrace with aluminium sprockets and notice very little wear if any. Granted I'm not eating up miles like road riders but I'm hard on them every second the bike is running. Plenty of far more powerful bikes running aluminium sprockets.
Offline Erny
Not long time ago I checked options with for K7 going from 630 to 530 chain. Primary reason was my friend who has K7 with chain to be replaced and secondary to prepare my replacement for the future.
Stock 630 (88 links) has 15/41 ratio, front sprocket has flange on outside rear is flat.
References from JT catalogue are JTF331 http://www.jtsprockets.com/catalogue/sprocket/JTF331/ and JTF333 http://www.jtsprockets.com/catalogue/sprocket/JTR333/
Calculated centers distance 566mm
practically 1:1 equivalent in terms of ratio, spockets centers distance is 530 chain (102 links) 16/43, front JTF338 http://www.jtsprockets.com/catalogue/sprocket/JTF338/, rear JTR284 http://www.jtsprockets.com/catalogue/sprocket/JTR284/. Calculated distance 571mm.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Pielz
Thank you for the info!! That's super super helpful. So I see the 530 options have the 2 bolt mounting system. I'm guessing that won't matter?
Also the 530 option, the 16/43 gives me a final drive ratio that's less than my current. Won't that make the bike feel a little less snappy on the low end? Or does that not matter as much as I think it does? Id like to raise it if possible.
« Last Edit: November 23, 2019, 05:02:51 pm by Pielz »
Offline Erny
if you want to change ratio, just select different front and/or rear sprockets.
You can use sprocket calculator here to compare options : https://sprocketcalculator.com/
also more detailed info incli. centers distance is here : https://www.blocklayer.com/chain-sprocket.aspx
Offline Pielz
Oh okay I see! And it tells me the estimated number of links. See, ive never done this before so I'm not sure how to know the lengths of chain and all of this. I just really want to make sure I do this right. I'm thinking about doing 16/48. That should give me the ratio that I'm looking for.
Be sure u go the right way? Going from 3 to 2.7 will increase mph, lower rpm at speed. If u want quicker take off u go the other way. Once u get the conversion on, u can change only the front sprocket for mph, or take off. I have 2 front sprockets, a 17 for take off, and a 18 for long trips.
