Author Topic: 67.5 mm =cc??  (Read 5274 times)
Offline lash
67.5 mm =cc??
« on: November 24, 2019, 03:37:43 PM »
836 is 65.5 so what would 67.5 be?
Re: 67.5 mm =cc??
« Reply #1 on: November 24, 2019, 05:35:58 PM »
836 Is 65mm  I think.  67 .5 is around 890 or 915 ish.  And will require sleeves, and maybe case boring.
Offline lash
Re: 67.5 mm =cc??
« Reply #3 on: November 24, 2019, 05:48:50 PM »
I picked up a bunch of engine parts last year and there was a box with cylinders and brand new pistons and rings. Just finally looked at it today and the ring boxes are labelled 67.5. Bore measures the same. Pics tomorrow, maybe somebody  an identify the pistons..
Re: 67.5 mm =cc??
« Reply #4 on: November 24, 2019, 05:52:21 PM »
Better tell us if cases are bored, if they are not its step sleeves, probably a Henry Abe kit.
 If sleeve bottoms are same diameter as stock, I will guess Henry Abe with cast pistons.
Offline lash
Re: 67.5 mm =cc??
« Reply #5 on: November 24, 2019, 05:58:56 PM »
I’ll post the pics tomorrow :)
Re: 67.5 mm =cc??
« Reply #6 on: November 24, 2019, 07:33:30 PM »
I'm betting Henry Abe too. ;D
Offline Tracksnblades1
Re: 67.5 mm =cc??
« Reply #7 on: November 24, 2019, 09:19:42 PM »
Quicker....?
Age Quod Agis
Re: 67.5 mm =cc??
« Reply #8 on: November 25, 2019, 12:05:51 AM »
Important to be aware of the reall cc when ordering rings from CycleX to their "915cc" kit that use 67.5mm pistons. It should be called 900cc.
Dynoman sell a real 915cc kit, 68 mm pistons and sleeves that must have case bore.
« Last Edit: November 25, 2019, 12:08:39 AM by PeWe »
Re: 67.5 mm =cc??
« Reply #9 on: November 25, 2019, 12:07:05 AM »
65.5 is 849cc
Offline lash
Re: 67.5 mm =cc??
« Reply #10 on: November 25, 2019, 08:08:32 AM »
Here are the pics.
Re: 67.5 mm =cc??
« Reply #11 on: November 25, 2019, 10:47:56 AM »
Im sure other guys soon will chime in with exact description of those pistons that look like old design.
You will need better rods if using that kit ;)
Like APEs rods.
Re: 67.5 mm =cc??
« Reply #12 on: November 25, 2019, 02:06:06 PM »
What makings are inside the pistons. HAINST is Henry Abe. They made 2 different pistons in their kits.
Offline lash
Re: 67.5 mm =cc??
« Reply #13 on: November 25, 2019, 02:47:00 PM »
Only markings I could find...
Re: 67.5 mm =cc??
« Reply #14 on: November 25, 2019, 03:23:41 PM »
I think that pic eliminates it as a Henry Abe. Possibly a CycleX? Can't say as mine are inside my engine. I do have the ring box at home.
Re: 67.5 mm =cc??
« Reply #15 on: November 25, 2019, 08:22:57 PM »
There is a W on the pin boss, looks like maybe Wiseco..
Offline lash
Re: 67.5 mm =cc??
« Reply #16 on: November 27, 2019, 02:10:33 PM »
Any idea on what this would be worth? I dont really want to get into big power parts, the engine I’m building is going into a bike for my wife..
Re: 67.5 mm =cc??
« Reply #17 on: November 27, 2019, 05:05:27 PM »
It looks like they've installed bigger sleeves so whoever buys it will have to have their top case machined to accept them, plus heavy duty rods etc. Because of this they won't be of interest to someone looking for a cheap HP gain, when an 836cc kit will give them almost as much grunt without the big increase in cost.
If someone is going the high HP route they might prefer a more modern kit (I could be wrong but the ring lands look like they're set up for 1 piece oil rings, which are not ideal) but for someone not as picky, that is still a good kit, so maybe 200-300 bucks? ;D
Offline lash
Re: 67.5 mm =cc??
« Reply #18 on: November 27, 2019, 05:13:34 PM »
I have the head for this but didnt check it to see if it has been machined. Will do that tomorrow.
Re: 67.5 mm =cc??
« Reply #19 on: November 27, 2019, 05:17:43 PM »
No worries, take a look at the ports too, if it's been ported nicely, it may be of more interest than the big bore kit. ;D
Offline BPellerine
Re: 67.5 mm =cc??
« Reply #20 on: November 27, 2019, 05:24:33 PM »
xc rings are weisco,and not 1 pc oil rings so modern pistons,put a bigger base gasket on and use as a template and grind away.bill
1978 CB 750K ard and webers
another anfob
Offline lash
Re: 67.5 mm =cc??
« Reply #21 on: November 27, 2019, 05:56:43 PM »
Not sure what you mean about bigger base gasket and grind away?
Re: 67.5 mm =cc??
« Reply #22 on: November 27, 2019, 06:54:06 PM »
The "Blue Ridge Mountain engineer" method of boring each cylinder hole in your top case is to put the oversize base gasket in place, mark the cases tracing the bigger holes, remove the gasket and get stuck into it with a die grinder or dremel tool, File, Bowie Knife,  or whatever cutting instrument you have available, usually conducted while drinking moonshine and wearing Dickies overalls and a straw hat. ;D
Re: 67.5 mm =cc??
« Reply #23 on: November 27, 2019, 08:55:43 PM »
Sure case need to be opened up for sleeves? The sleeves look thin as the tapered sleeves look like with 67.5mm bore.
My K6 needed a little Dremel massage while my K2 did not.
Re: 67.5 mm =cc??
« Reply #24 on: November 27, 2019, 09:59:38 PM »
I told him, measure or compare to stock sleeves..
 Or look at holes in the case, stock I believe are unmachined..
 Am I the only one that sees the W ?
 I might be interested in them , I would have stock parts to trade towards.   And I am in Canada.
« Last Edit: November 27, 2019, 10:02:29 PM by 754 »
