Author Topic: Mystery Oil Droplets After 30min Ride?  (Read 2354 times)
Offline SalNYC750
  • I’m a big fat Italian Guy so sue me!!!!
Re: Mystery Oil Droplets After 30min Ride?
« Reply #25 on: December 02, 2019, 03:08:27 AM »
Actually fellas I’m starting to think it’s from the oil pressure gauge, the random droplets have stopped but the poooling of oil (just a light coatin on my finger tip) see picture still happens after a high RPM run of 15-20 miles... :o :o :o
only got about 500 or so miles outta the last oil change, black as tar however the filter looks good no metally bits or anything floating around.
why would oil go black so fast? I don’t have any whiteish smoke unless I really rev hard :P
im not the sharpest tool in the basket so big NYC thank youz guys to all who help this lunk!!!!
74&72cb750 in various states of disrepairs!
Offline jgger
« Reply #26 on: December 02, 2019, 05:34:05 AM »
Oil goes black fast because it is a detergent oil. It's doing it's job.
Offline SalNYC750
« Reply #27 on: December 02, 2019, 08:41:03 AM »
Even standard econo-Dino? I use the base store brand 10-40 off the shelf @ part stores.
Offline Maraakate
« Reply #28 on: December 03, 2019, 06:38:10 PM »
Yes, however I wouldn't put any economy no-name brand stuff in it unless you are careful.  Make sure it is not the "starburst" logo'd oils as these may have additives that will not work well with your bike causing clutch slippage.  However, if it's riding fine with whatever you are using then don't worry about it.
1977 CB550K
1979 CM400A
