Author Topic: nighthawk wheels  (Read 342 times)
Offline tlbranth
nighthawk wheels
« on: December 09, 2019, 05:29:30 PM »
Anyone know if nighthawk wheels would work on a cb750k? Any customizing involved?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Re: nighthawk wheels
« Reply #1 on: December 09, 2019, 07:14:19 PM »
 77/78F's have the 5 bolt brake rotor pattern and different offset, most other sohc 750's have a six bolt rotor. I'm sure it's not a direct bolt on swap but I'm betting someone has tried it.
Offline tlbranth
« Reply #2 on: December 09, 2019, 08:34:58 PM »
It looks like the 99-02 (or so) rims are tubeless mags. Sure like to make that change. My CB is a '70.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #3 on: December 09, 2019, 10:08:13 PM »
Check bearing size, the Nighthawk 16 rear I have was shaft drive, that can be adapted  to non sch drive sprocket. It had a drum brake  but was 17mm axle size.
