Author Topic: Side kick CB 500 Four  (Read 903 times)
Offline remcoseegers
« on: December 13, 2019, 11:38:35 AM »
I installed the 4 in 4 exhaust which was quite a job... I finally managed and man this it look better now! The only issue I have is with the side kick. The spring touches the pipe and I cannot use it without pushing the pipe inside. Does this happen to you? Any idea why this occurs?
Offline Menno
  • www.tanklackieren.de
Re: Side kick CB 500 Four
« Reply #1 on: December 13, 2019, 12:48:15 PM »
Could you post a pic of the actual location of your side stand?
I mean where it is mounted on the frame..
Offline Deltarider
« Reply #2 on: December 13, 2019, 01:57:29 PM »
Remco, I'd advice you first to check here if you've fitted the exhausts brackets correctly. Before I had them both on the outside of the frame eye which is wrong. One bracket is supposed to be on the outside of the frame eye and the other on the inside. http://forums.sohc4.net/index.php/topic,82323.msg925422.html#msg925422new Have you bent the brackets by any chance?
« Last Edit: December 13, 2019, 02:03:18 PM by Deltarider »
CB500K2-ED Excel black
« Reply #3 on: December 13, 2019, 02:06:23 PM »
I think I installed well. Was quite a job but at the end it looks ok. I think that just the spring ofthe stand is giving problems. I need one with less diameter.
« Reply #4 on: December 13, 2019, 02:11:20 PM »
It looks a lot better with the 4-4 exhaust and also the sound is way nicer! Tomorrow I will fix the stand, if I cannot find a good spring I might just take the whole thing off for the time being.
I was very happy to find this original set!
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: December 13, 2019, 02:15:46 PM »
You have the pipes installed incorrectly.  #1 header should be on the left of the side stand, and #2 header should be on the right side of it.
« Last Edit: December 13, 2019, 02:19:52 PM by Gordon »
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #6 on: December 13, 2019, 02:18:27 PM »
You have it wrong, number 2 goes on the inside of the stand  ;)
Like so  ;)
« Last Edit: December 13, 2019, 02:23:40 PM by trigger »
« Reply #7 on: December 13, 2019, 02:20:10 PM »
Will that even work? I will try tomorrow then 😛
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: December 13, 2019, 02:25:17 PM »
I'm actually kind of surprised you were able to mount them the way you did.  I think you'll find they go on a lot easier the other way.  Just make sure, like Deltarider said, to have one mounting bracket on the inside of the frame tab and the other one on the outside.
« Reply #9 on: December 13, 2019, 02:27:49 PM »
Haha, it wasn't easy no... but thanks to you now I know why it was not easy... tomorrow morning I will fix it. Thanks a lot for the help!
Offline jamracing
« Reply #10 on: December 13, 2019, 03:26:44 PM »
I spent half a Spotify Playlist on those damn headers lol!
Sent from my iPhone using Tapatalk Pro
Offline Deltarider
« Reply #11 on: December 14, 2019, 12:38:13 AM »
I owe many thanks to Sohron for his beautiful pictures* and detailed description and also Ashimoto who gave us pics that show how brackets can be checked for the correct shape. Helped me a lot. Glad to pass it on.
* Is it just me that now - thanks to Photobucket -has them blurred? Anyway, I've downloaded the Sohron CB550 Assembly Manual that shows them unblurred. So let me know.
« Last Edit: December 14, 2019, 12:50:24 AM by Deltarider »
« Reply #12 on: December 14, 2019, 04:35:35 AM »
I changed it to the right position. A shame I did not think of that yesterday... would have saved me a lot of blood & sweat lol. Now it is perfect. Thanks again!
« Reply #13 on: December 14, 2019, 11:53:13 AM »
Glad you got it sorted.  Nice looking bike with the stock pipes and cool seat
