Author Topic: Stumped by a rear brake issue.  (Read 936 times)
Offline Pielz
« on: March 31, 2020, 11:50:55 AM »
I've tried searching the forums and followed all the directions but I feel like I'm missing something. I installed new brake shoes in to these old comstars. They clear fine, no dragging or anything. I go to hook up the brake lever arm to the pedal and I'm getting the right amount of play in the brake pedal, but if I turn the adjustment nut any farther, the brake engages and drags without depressing the pedal. Is this a normal amount of adjustment? Here are some pics that will hopefully prove something.
All levers are lined up with their respective dimples and the brake pedal height adjuster nut, as you can see, isn't even there so it should have maximum play.
I don't have the chain on yet by the way. Is it an issue of the rear wheel being too far back because it's not adjusted forward via chain? Although this was an issue on this bike before the new wheels when the original 630 chain was still on it
« Last Edit: March 31, 2020, 11:52:44 AM by Pielz »
Offline barrynoname
Re: Stumped by a rear brake issue.
« Reply #1 on: March 31, 2020, 11:53:25 AM »
If the wheel cant move forward than this is not normal, check of everything is okey behind the cover.
Offline Pielz
« Reply #2 on: March 31, 2020, 12:03:33 PM »
I wonder if somehow my brake lever arm is shorter than it should be? Hmm. Was planning on putting the new chain on today but ran out of time before work. There's probably some room for the wheel to move forward and I had a brain fart and as I said, it's sitting without a chain on it right now. I'll see if I can get the chain on and pop back in to update and see if I've just embarrassed myself more than usual by asking about this haha. I'm a newbie at this and still learning.
Offline 69cb750
« Reply #3 on: March 31, 2020, 12:32:29 PM »
Move drum arm (ignore dots) so nut gets on rod.
Offline ADW
« Reply #4 on: March 31, 2020, 01:13:27 PM »
Agreed to go ahead and move the brake arm at the wheel a notch or two off the dimples to get enough thread on the nut/rod. It won't hurt anything.
« Reply #5 on: March 31, 2020, 01:27:59 PM »
Has the end of the rod been broken off?
Offline Flyin900
« Reply #6 on: March 31, 2020, 01:29:14 PM »
Possibly the splined cam that goes through the hub is 180 degrees out if it was removed did you or a PO put it back in correctly. The pictures are too close to tell, yet the brake arm off the splined cam on the rear shoe looks weird in that position, although it maybe just the picture.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: March 31, 2020, 02:15:33 PM »
Is the backing plate brace bolted on and the drum n the right place (rotationally)? We’re these Comstars original to this bike?
Offline Pielz
« Reply #8 on: March 31, 2020, 02:26:07 PM »
The comstars are not original but were closely examined and compared with the original parts and are directly swappable. I've read everyone's replies and I appreciate it. Tomorrow evening I should be able to check on some of the things that you guys suggested. I'll make sure I update back even if it's something really stupid and embarrassing lol
And I don't believe the threads were broken off at any point. Although if it happened 20 years ago the evidence is probably buried under some surface rust
Online pjlogue
« Reply #9 on: March 31, 2020, 05:02:17 PM »
Not sure what year model bike you have but I had a similar problem with the same issue when I went to reassemble my rear break on my '76 750.  Turns out I had the clevis end of the brake rod turned down instead of up where it attached to the brake lever.  You might check the orientation of the clevis.
-P.
Offline Pielz
« Reply #10 on: March 31, 2020, 05:08:06 PM »
-P.
I'll do that! Thanks!!
Offline BenelliSEI
  • 1969 cb750
« Reply #11 on: March 31, 2020, 05:48:16 PM »
+1 to JPL. I’v made that mistake too.
« Reply #12 on: March 31, 2020, 08:14:04 PM »
If your bike originally had a 630 chain, it must be a '77 or 78 model (you didn't say?) which had a longer swingarm than earlier 750s. Is it possible you have the earlier, shorter brake rod? Measure the length from the center of the clevis pin to the threaded end of the rod.
Offline Pielz
« Reply #13 on: March 31, 2020, 08:15:05 PM »
That's absolutely possible. This bikes history is questionable at best. I'll measure and check it out as soon as I'm able!
« Reply #14 on: March 31, 2020, 08:20:20 PM »
I'll measure a known K7 rod when I get the chance...
Offline Pielz
« Reply #15 on: March 31, 2020, 08:20:58 PM »
Thank you I'd appreciate that greatly
Offline Pielz
« Reply #16 on: April 02, 2020, 05:59:38 PM »
Sorry for the anticlimactic ending to this saga but I disassembled the rear brake pedal assembly to inspect it and when I buttoned it back up it fit up properly and I seem to have the correct amount of adjustment. Honestly I have no clue what I did or what I fixed but it's working now.
Is it possible the return spring was binding up or something?
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #17 on: April 03, 2020, 03:53:48 AM »
 ;D Well done. It’s puzzling, but nice when that happens!
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline Pielz
« Reply #18 on: April 03, 2020, 08:30:12 AM »
Definitely! Lol
