Author Topic: 400/4 head bolts/ studs.  (Read 1369 times)
Offline Tomshep
« on: December 21, 2019, 10:47:47 AM »
My bike has been sitting in a barn in France for a while and needs to be repatriated. Time I got on with the work.
I have a '76 with the short head bolts or studs. It weeps so I am intending to change the head gasket over the Christmas break. Is it feasable to change them out for the long ones to keep the engine oil tight? I haven't really understood why the bolts are an improvement; are they bedded deeper into the upper crankcase to allow for a bit more torque up top? If so, are the earlier engines threaded deeply enough to allow the longer ones to be used or have I got the wrong end of the stick?
Thanks for reading this and thanks again if you can advise me.
Offline robvangulik
  • Honda Fourever
Re: 400/4 head bolts/ studs.
« Reply #1 on: December 21, 2019, 01:37:12 PM »
If I remember correctly the difference in length is about 1 millimeter?
And it was oiltight for some 40 years? I'd renew the gaskets and wait for the next 40 years ;)
Offline Kevin
« Reply #2 on: December 21, 2019, 07:26:49 PM »
This is the first I have heard of longer cylinder studs, I know the exhaust studs on the F2 were longer.
I'd just replace the head and base gasket, be sure to also replace the copper washers too.
I have installed A.P.E. heavy duty cylinder studs on a few of my high performance engines but I do not think they are necessary on a stock engine.
Sent from my SM-N960F using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline robvangulik
  • Honda Fourever
« Reply #3 on: December 22, 2019, 03:00:44 AM »
This is what I think he was referring to, the complete  guide was too big to upload so this is the part that matters
Offline Tomshep
« Reply #4 on: December 22, 2019, 03:10:42 AM »
Thank you very much. That was exactly the information I needed. I think my bike is mid '76 but the frame number is a huge help as I shall know one way or the other.
« Last Edit: December 22, 2019, 03:52:43 AM by Tomshep »
Offline Kevin
« Reply #5 on: December 22, 2019, 03:19:31 AM »
Thanks Rob, I learn something new every day.
Great information and I think some he is refering to UK bikes.
My USA spec F2 has pillion pegs on the swing arm. I'm sure it is stock...it only has 701 original miles.
Offline robvangulik
  • Honda Fourever
« Reply #6 on: December 22, 2019, 03:44:50 AM »
If I remember well that guide came from the UK sohc site....
Offline Tomshep
« Reply #7 on: December 22, 2019, 03:53:48 AM »
Yes, the bike is in France but was exported from Britain. It is now due to come back.
Offline robvangulik
  • Honda Fourever
« Reply #8 on: December 22, 2019, 04:45:00 AM »
This should give you the rest of the article http://www.sohc.co.uk/index.php/topic,19303.0.html
Offline Nurse Julie
« Reply #9 on: December 22, 2019, 10:33:06 AM »
Tom. As yours is a UK bike and it's coming back to UK, maybe consider joining us on SOHC.co.uk if you haven't already?
Trust me I'm a Nurse, I promise it won't hurt....much
Offline Tim2005
« Reply #10 on: December 22, 2019, 10:40:22 AM »
Presumably that's a 77 bike? The US 77 models had the pillion pegs like that. It's odd that they moved back to that earlier configuration, I've no idea why.
And as for the rest of the topic, I wouldn't bother changing the studs, I've never seen any evidence that this modification made any difference. Also removing the studs can be extremely difficult.
Offline Redline it
  • thread killer
« Reply #11 on: December 22, 2019, 12:34:18 PM »
where do you get those copper washers?
Online bryanj
« Reply #12 on: December 22, 2019, 02:25:36 PM »
Genuine Honda parts
