I got a 2nd thought about the reused MLS headgasket after a quick compression test that showed lower compression and too much difference between cylinders despite all 4 chambers are really equal and not larger than previous head.
Latest head 23.6cc, earlier 23.7/23.8cc that gad 197.5-202.5 PSI with thicker base gasket.
I expected more, all around 200-205PSI.
Pistons around CR 11:1 with 22.5cc chambers
I have measured several times and compared with old (100whp head).
Same cam 1 degree earlier.
Thinner base gasket should crank up compression too. Reduce total chamber size by 1cc.
Head off and new MLS gasket(s), ordered. (Fiber too just for sure and ev. future fixes)
Dynoman Texas.
I do not know any closer for MLS 72mm
Did the wheels. Late surprise, 3 spoke nipples short on rear wheel. Contacted seller that responded direct to ship missing nipples.
I can do the front wheel.
Tighten, truing and mount the 90/90-19 tire. Can mount it on bike too.
![](https://uploads.tapatalk-cdn.com/20210312/8424851189116a4ed9a5be8f1b94028c.jpg)
![](https://uploads.tapatalk-cdn.com/20210312/bec09d3897d07ed32a3bbc33c7fb3215.jpg)
