Hi Johno,
Your experienced comments and thoughts are greatly welcome!
Last dyno (blue) a day with worse weather and a rotten drive chain that looked to snap in any minute, instructed the dyno guy to avoid heavy throttling. It was more to verify last jetting adjustments. Before too rich at idle and around 3500-6000 area.
I have reduced needles 1/2 notch after that last dyno in blue.
Dyno charts do not show idle and steady crusing speed 120-140kmh that were too rich.
I saw what the rich jetting had done during a very short time when lifting the head a month ago. 1585km after last head change when pistons were cleaned to shine.
That helped me to trust the dyno guy's recommendation to reduce needles more than my idea about 1/3 notch to 1/2 notch.
Initially 3:6 notch from top changed to 2nd + washer. Too rich fuel screws a limited time a part of all carbon too, adjusted before last dyno by 1/3 turn less. 1 1/8 to 3/4.
One step richer pilots fixed the balance further to the needle area (32.5-->35)
I wonder if compression will increase which might need leaner jetting again.
I felt the difference when finally hitting the 100whp area. Probably the increased compression that did it.
Last head for longetivity, stock guides shortened 3mm in port area and sunked deeper to ensure higher lifting cams. 11.5mm lift does not hit guide seals.
Another thing where valves and pistons will set the limit.
33.5/28.5 mm KPMI valves.
The throats might not loose that much compared with 34mm valves. I did not measure, maybe same size as the 99-101whp head.
Lets see if compression will increase with thinner base gasket and a little bit smaller chambers. Now 23.6cc, before 23.7/23.8cc. 197.5-202.5PSI with a cheap tester.
The pistons ring lands might complain if too high. JE forged pistons must be challenged to do what constructed for!!
Correct compression for power and less need of fuel.
It's OK if it will reach 9000 rpms on 5th gear rather quick. At least a constant acceleration up to 210kmh, the final step to 220kmh a little bit slower.
Same cam, Megacycle 125/75.
IO opened at 26* at 0 lash as camcard last time.
If I retard it, maybe a little bit extra at and after 9000 rpm. 1 degree later if that will be noticed.
Piston and ex valve should not complain about that small difference, I hope.
Tune with more valve lash might not be possible if compression is at the limit.
Most fun on street should be an advanced cam by a few degrees if clutch will allow it.
Engine is currently waiting for new head gasket. The old did not like to be reduced.
Rigid HD studs and metal gaskets should have less need of high torque.
I have thoughts about head-cylinder package swelling when hot. Studs might not extend in lenght matching that, ending up in nuts to dig deeper into head.
Fiber gaskets can give, but not RCS and MLS.
My old ported head with 5mm stemmed valves had nuts sunken rather deep, especially ex side.
Before always 27-28 Nm (20-20.6 ft lbs), next time 25Nm (18.44 ft-lbs), retighten the day after as usual.
(Later found 25Nm not enough for MLS to seal, 20-22 ft lb needed.)
My wife prefer my brown K2, almost stock with 4-4, 57 whp. Not that sudden throttle response as this bike.
My K6 with Hindle 4-2-1 not that loud as my K2 with 4-4 no numbers at steady cruising 100-120kmh.
The latest head not yet started.
I'm happy to have seen the tight oil holes in time. All holes fine tuned by a 9.0mm drill. Oil feed holes got another round with 9.5mm drill.
I started a thread about it with really good feedback from others.
I like to be the rider on common roads. A road racer!
Feel the improvements not really affecting top speed, more about reaching it quicker before road is out of stock!!
Last dyno with the K2 head with F2 invalves....
Photos of latest head (392) not yet tested. Camera does not show how correct chambers are shaped and aligned vs gasket (72mm MLS).
