Bike is waiting for spring with a rear tire that has around 1000km left, plus a dyno run.
I have not yet tested the new rear wheel I built one year ago with 3.0-18 rim. Had to use up a tire on stoch rim first.
Tire in garage not yet mounted and I already look forward for next change.
Tire to be used first Metzeler Roadtec 01 120/80-18 diameter close to stock 4.0-18
Next rear tire wider 130/80-18.
Matching front 100/90-19 on 2.15-19 rim as has 90/90-19 now.
Metzeler has not the Roadtec 01 in 130/80-18.
Michelin has, Road Classic.
So I need to ride up the existing tire on bike.
New 3.0 wheel with Metzeler 120/80-18 and ride it up too. Cannot use it on another bike when 120/80 need wider rim than 2.15.
Then time for the Michelin 130/80 tire.
Later change Metzeler front to Michelin too, 100/90-19.
So I have rides to be done.
Metzeler Roadtec 01 is a good stable tire. Like it, 2 rear done. 4.0-18 and 120/90-18, the latter no longer available/produced. 120/80 on their list.
Next tire I look forward to test as wider rear. Rather new model. Front will come too.
I have compared the rear wheel radius. I choosed 120/80 since it was closer to stock 4.0 than 120/90.
4.0-18 - 326.39mm
120/90-18 - 336.6mm
120/80-18 - 324.6mm
130/80-18 - 332.6mm
My thoughts now is that a 130/80 might live longer and handle the power better.
3.0" rim allow that width.
