Author Topic: CB750K6 -76 project back to life with more updates  (Read 36393 times)
Offline Kaze
Re: CB750K6 -76 project back to life with more updates
« Reply #350 on: September 22, 2023, 12:25:06 PM »
"Dad! I think there's a UFO behind us!" "No Jimmy, that's just the Sun. ...and 2 stars."
One man's rubbish is another man's project.
« Reply #351 on: September 22, 2023, 03:48:23 PM »
If you can find good gasoline within bike range. You  can ride your bike to fill it up. Back home and prepare for next ride to good stuff for your bike.
Can be a good reason for rides.  ;)
Biker friendly roads with tasty low cost food.
Yes indeed,which makes for a great ride  ;)
Offline Kelly E
  • Geriatric Hooligan
« Reply #352 on: September 22, 2023, 08:21:04 PM »
I can ride my 94' Kawasaki ZG 1000 A9 Concours Super Tanker to the gas station and fill it up. It holds 7.5 gallons so I can fill another bike and still have at least 2.5 gallons left. That's enough to fill a Sportster. 8)
My buddy says that I should install an electric fuel pump, valve and hose in the fairing pocket so I can rescue Magna's, Rebel's and Sportster's. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #353 on: September 22, 2023, 10:02:50 PM »
It would be fine if CB750 tank contain +50% more ;)
Easier to ride longer.
The higher octane fuel with less ethanol is not served everywhere here.
« Reply #354 on: September 22, 2023, 11:01:20 PM »
I agree Per.
Back in the late 70s when I rode my K6 cross country 5 times, I wanted to find a 6 gallon tank to put on it.
Offline Kaze
« Reply #355 on: September 24, 2023, 01:00:18 AM »
- Fiberglass tape. Thanks for the tip. Never heard of it.
- Where did you put the fuse?
« Reply #356 on: September 24, 2023, 09:32:29 AM »
Fuse inside headlight bucket.
« Reply #357 on: October 30, 2023, 10:36:38 AM »
Got new levers for clutch and hand brake today.
Clutch is a pig with stiff  springs to avoid slip.
It feels better for a finger or 2. Brake too.
5-6 months waiting for test ride ;D
Newer bikes have adjustable alternatives.
These will due, better than before and look better.
« Reply #358 on: October 31, 2023, 06:35:21 AM »
Bling bling, levers look good!  I like those grips too, havent seen them before.
« Reply #359 on: October 31, 2023, 06:53:15 AM »
Found in USA.
When I knew what to search fore more sellers. Dog leg lever.
I hope clutch will feel a little bit lighter with that shape of the lever.
Like mine. I bought my set from a private person that sold them as Emgo parts.
These look similar.
https://www.ebay.com/itm/182294173657?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=HhuI_Oi1SWa&sssrc=4429486&ssuid=XgCEg0CPSya&var=&widget_ver=artemis&media=COPY
« Last Edit: October 31, 2023, 09:37:16 AM by PeWe »
« Reply #360 on: October 31, 2023, 07:42:12 AM »
I had to compare too see how much better. Closer to grip. Stock taped under.
Frequent use of clutch will feel better for my office left fingers. ;)
The brake has a better grip too.
Offline denward17
« Reply #361 on: October 31, 2023, 08:06:55 AM »
I really like those levers!  They look polished to.
« Reply #362 on: October 31, 2023, 08:54:48 AM »
They are polished ;)
I like them better than I thought when ordering.
Offline denward17
« Reply #363 on: October 31, 2023, 09:03:09 AM »
They look different than the link you posted?
« Reply #364 on: October 31, 2023, 09:34:48 AM »
Thanks for the notice.
You are right, I added wrong link. I have edited the post.
This is the set I bought.
https://www.ebay.com/itm/195790062061?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=9491Ff0XSvK&sssrc=4429486&ssuid=XgCEg0CPSya&var=&widget_ver=artemis&media=COPY
« Last Edit: October 31, 2023, 09:36:29 AM by PeWe »
« Reply #365 on: November 02, 2023, 07:16:12 AM »
EMGO brand - China....but hard to screw up an aluminum lever!
« Reply #366 on: November 02, 2023, 08:52:24 AM »
They look good and work fine.
Normal use will work.
I'm eager to test how easier the stiff clutch will feel. Plus the braking power.
Another thing if bike will be dropped.
The lever must go instead of the switch housing or mc if lever hits the ground.
My K2 has only cheap aftermarket stock style levers. Stock Honda is thicker and cost more than double.
« Reply #367 on: July 05, 2024, 10:05:26 AM »
Update:
The dog leg type of levers are very comfortable. Have used them for a while now.
Ordered for my K2 too plus 2 extra sets plus blank points covers from vintagecb750.
« Last Edit: July 05, 2024, 10:07:23 AM by PeWe »
« Reply #368 on: July 06, 2024, 10:42:53 AM »
That clutch lever is an excellent option, to keep things matching, if you use a more modern master cylinder or perhaps the Nissin Retro Master Cylinder...they all seem to use a dog leg lever
« Reply #369 on: July 06, 2024, 12:37:01 PM »
That might be an option for the weak braking single disc K2.  If finding a good looking one cheap ;)
« Reply #370 on: July 11, 2024, 10:31:33 AM »
Adjusted the fork by removing washers under the fork caps.
Progressive fork springs from Wirth.
3.65 mm washers did raise the bike, less sag.
Result: Harder ride, feeling of higher center of gravity.
No washers, much better stance and handle corners better.
This should be adjustable without taking things apart.
Test ride made me to ride wilder than usual on a country road surrounded by dense forest.  ;D
Carbs got bigger mains to compensate for the correct and leaner needles. Fun response.
I have to watch out for the horns not growing too much when riding the K6.
Offline Kelly E
« Reply #371 on: July 11, 2024, 06:14:12 PM »
Maybe you better drill a couple of holes in your helmet to let the horns out. ;D
1983 Honda CB 1100F
« Reply #372 on: July 12, 2024, 01:09:46 AM »
;D ;D
« Reply #373 on: August 11, 2024, 01:58:35 AM »
K&N pod filters trickier to fasten after 9 years.
The clamps glides off, going backwards with the filter.
Easier with a distance ring keeping hose clamp in place. I should have done that from the very beginning when pods were new.
This has been a problem the last years, becoming worse.
A cable tie used as a spacer helped.
Carbs look dirty when zoomed in, need a clean ;D
I have new filters found on sale as spares ;)
The K&N filters cost a lot more today than 9 years ago.
I might find out a slightly wider and thicker plastic ring alternative. Clamp can be better seated. Filters stays where they are, so OK
« Last Edit: October 24, 2024, 08:59:53 AM by PeWe »
