SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Front brake rotor CB750A versus GL1000
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Front brake rotor CB750A versus GL1000 (Read 371 times)
jukku
Enthusiast
Happy with my Hondamatic
on:
January 02, 2020, 01:54:47 PM »
Front rim Comstar 1.85x19" on CB750A -78 and GL1000 -78, calipers are different but are the rotors interchangeable? Diameter, offset, thickness?
Logged
bryanj
Really Old Timer ...
CB500 Number 1000036
Re: Front brake rotor CB750A versus GL1000
Reply #1 on:
January 02, 2020, 01:58:30 PM »
Check the part numbers at cmsnl
Logged
754
Reply #2 on:
January 02, 2020, 03:43:07 PM »
More offset smaller diameter on 75, 76 GL rotors so I suspect any GL may not swap.
Last Edit: January 02, 2020, 06:13:55 PM by 754
Logged
Kelowna B.C. Canada
Medyo Bastos
Master
Gusto mo titi ko?
Reply #3 on:
January 02, 2020, 04:26:19 PM »
Year you’d have to run a gl front end yo make them work. I have a box full of them under my bed.
Logged
dig'n
http://forums.sohc4.net/index.php/topic,132180.html
boost'n
http://forums.sohc4.net/index.php/topic,143927.msg1636671.html#msg1636671
Bankerdanny
Eventually I will be old enough in reality to be
Endeavor to persevere
Reply #4 on:
January 03, 2020, 12:10:55 PM »
The GL used calipers mounted directly to, and behind the fork leg. The '78 750A still used the pivoting bracket mounted caliper that all K model bikes had. So it is likely that the dish and diameter of the single disk 750A rotor is different than that of the twin disk GL.
Logged
Current: '76 CB750F. Previous: '75 CB550F, 2007 Yamaha Vino 125 Scooter, '75 Harley FXE Superglide, '77 GL1000, '77 CB550k, '68 Suzuki K10 80, '68 Yamaha YR2, '69 BMW R69S, '71 Honda SL175, '02 Royal Enfield Bullet 500, '89 Yamaha FJ1200
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
