Author Topic: 1974 Rickman Honda  (Read 37097 times)
Offline smcgill
Re: 1974 Rickman Honda
« Reply #125 on: March 21, 2020, 05:29:35 PM »
   Good progress John! I mounted pipes today.
                                Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Rickman CR750 [project in progress]
Offline BenelliSEI
  • 1969 cb750
« Reply #126 on: March 21, 2020, 05:37:25 PM »
Frank...... PM sent.
Scott........nice installation! PM sent. John D.
« Last Edit: March 21, 2020, 06:09:33 PM by BenelliSEI »
Offline smcgill
« Reply #127 on: March 21, 2020, 07:26:14 PM »
John, I am not able to respond on P.M. [?] The tank rubbers are Kawasaki Mach3 sourced off E-bay, I cannot find the receipt from the vendor. Clubman Racing Accessories has them, I believe, listed as Norton Manx tank rubbers.[ try searching Ebay]  Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Offline BenelliSEI
  • 1969 cb750
« Reply #128 on: March 22, 2020, 05:26:59 AM »
Scott...... spotted them. Thanks! John D.
Offline BenelliSEI
  • 1969 cb750
« Reply #129 on: March 23, 2020, 06:10:04 AM »
OIL LEAK! Yesterday I spotted a small oil leak on the hoist table. The RHS frame down tube, clutch cable and “triangle” engine mounting plate were spotted with oil. Started the bike up and there is a small drip hanging off the head fin, next to #4 exhaust, inside stud. LASH was visiting and suggested a leaking cam box stud. It’s either that or a “puck” rubber gasket under the cam block.
So, apparently one advantage of the Rickman frame is the space to work on the top end. We’ll see. I’m going to try resealing the studs in the area (quick fix?) or eventually pull off the cam and do it all, in the frame. We’ll see.
« Reply #130 on: March 23, 2020, 08:17:40 AM »
If stud is leaking, thread in head can be bad if no insert installed.
Rubber pucks also visible in the sparkplug  cavity.
Small leak is irritating. It cause a lot of dirt.
Offline BenelliSEI
  • 1969 cb750
« Reply #131 on: March 23, 2020, 03:12:21 PM »
OIL LEAK Cont’d....... Today I tackled it. The Rickman frame is a joy. In a couple of short hours, the coils came out cam cover off, cam and cam boxes all out on the bench. Right after I pulled the cam cover though, had a HUGE “Oh sh*t” moment. On the right side cam box, the forward centre bolt was MIA. What was sticking out was the damaged end of a piece of 1/4” all thread, topped by a 1/4” NC “hardware store” crappy nut (7/16” wrench)!! The pictures shows it, next to the correct fastener (from the other side)....... a small job just turned into a career? Unscrewed the nut and used a small pair of vice grips to back it out, then removed everything else.
On close inspection, this head has none of the small fasteners drilled and tapped through to cooling areas of the head. I checked every one, cleaned them out, they are all blind. So, not leaking from there. Next, I cleaned everywhere and started picking out the rubber pucks. None had any extra sealer and centre one on the RHS (where the leak was ) is soaked underneath. So, problem solved.
On to that piece of crap stud! Obviously, someone lost the correct bolt and this was the solution. Fortunately the guy was so stupid, he cut it short, so only the first couple of threads were damaged. Used a leading tap, then a bottoming tap and cut the threads to the very bottom of the well. Cut down a new screw to reach in an extra 4 or 5 mm, so should all go back in.
The amazing part of this story is this motor came out of a K6 I bought a few years ago. It’s a 1974 motor. The previous owner paid a well known local shop big bucks to rebuild this motor. He then could never get it to run, and sold it to me out of frustration (plugged idle jet circuits). What a clown show in that shop!
P.S. when I removed the cam chain tensioner, the lower bolt, closest to the oil pressure switch was out a few threads, never tightened up! I’ll be pulling the rest of the covers and checking a few more details next.
« Last Edit: March 23, 2020, 04:23:07 PM by BenelliSEI »
Offline smcgill
« Reply #132 on: March 23, 2020, 07:40:33 PM »
  Sorry to see you have a setback, and kudos for going right after it! That stud "repair"[?], unbelievable. I'm worried my newly assembled engine may have issues also. I hope to fire it maybe by the weekend. I already appreciate the Rickman clearance for head work.
     Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
« Reply #133 on: March 23, 2020, 08:17:59 PM »
Perfect to find it before the riding season.  No need to lift head either for a bigger job.
Did you re-tighten head nuts just for sure when at it? M6 bolts under rubber pucks OK too.
(The mechanic might have done more short cuts.)
It is very easy to set valve lash with cover off.
« Last Edit: March 24, 2020, 12:39:49 AM by PeWe »
Offline BenelliSEI
  • 1969 cb750
« Reply #134 on: March 23, 2020, 08:22:03 PM »
Thanks guys! I thought I may as well dig in. Have yet to reassemble. Will definitely torque the head down before hand.
« Last Edit: March 23, 2020, 08:24:38 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #135 on: March 24, 2020, 02:45:16 PM »
Got an hour to start putting back the cam etc. Started by retorquing the head, this motor only has about 30 miles on it, after the previous owner had it rebuilt, 4-5 yeas ago. All pulled up the same small amount. Started cleaning up the cam baskets and caps and realized all four hollow dowels were missing. Also, all the cam journal caps were clearly marked for location and the two outer, end caps were switched.......
I’m surprised this motor runs as well as it does. I shudder to think what else might be “1/2 done”? It runs smoothly and put out great oil pressure, but I’m getting nervous. Next project (when the Rickman is finished) will be to put the race engine (no buyers) into a more roadworthy case, add back electric start and perhaps dial back on the cam selection.
Offline smcgill
« Reply #136 on: March 24, 2020, 04:35:05 PM »
  That sounds like an excellent plan, I'd be willing to bet that race engine was assembled with more care than your present one.I'm just jealous I don't have a spare race engine laying around.The guy who does my machine work talked me into letting him put 2 new cylinder  liners in, honing the other2. [they were within spec] I did not like the idea at the time, but he was confident all was good.Pre run compression check shows 170 lbs. in the 2 new cyls., and 150 in the older 2.Not real happy about it. I assembled with good quality U.S. rings gapped and staggered.I'm going to try and run it, if it seems livable, maybe the rings will seat to the probably slightly out of round bores.Maybe in the future, start again from scratch, and do it right, like some others here have.
   alternatively, I could take up a cheaper hobby, like personal submarines,or space travel.
             Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
« Reply #137 on: March 24, 2020, 05:21:27 PM »
Yep, buy your own or build your own sub and run shipments of toilet paper...  :) ;)
Heard DEA found two tons of toilet paper hidden in a cocaine shipment.  (Joking)
Offline BenelliSEI
  • 1969 cb750
« Reply #138 on: March 24, 2020, 06:32:45 PM »
What’s really surprising is the previous owner (of my K6 that I “borrowed” this engine from) gave me a stack of paperwork including the bills for the rebuild. He paid lots, to a shop that is still around and has a stellar reputation! I’m going to drop the pan, and all the other covers, to have a good look.
It does sound awesome on the Hindle pipe, and makes excellent oil pressure.........
« Last Edit: March 25, 2020, 05:01:23 AM by BenelliSEI »
« Reply #139 on: March 24, 2020, 11:40:58 PM »
Good thing with the Hindle is not that loud when crusing slowly with almost closed throttles.
Different when open the throttles!
Offline BenelliSEI
  • 1969 cb750
« Reply #140 on: March 25, 2020, 11:26:04 AM »
All back together, everything pulled up as it should! Nice to have a frame that allows the cam cover to lift off (after removing the coils). So easy to adjust valve clearances...... On any of my other cb750’s the engine would have to come out for that leak repair!
Offline BenelliSEI
  • 1969 cb750
« Reply #141 on: March 27, 2020, 12:21:29 PM »
Cleaned up both brake calipers today (both spotless and dry). Installed new pads at both ends and bled in fresh fluid. Both lever and pedal feel strong, with just the right amount of free play. Bought pads on EBay and they were a perfect match: Ferodo “Sinter Grip - Road”, FDB342ST.
Next steps will include refitting the alloy tank that came on the race bike (not original, but fits well and has double petcocks). When the weather improves just a bit more, I want to take this thing for a test ride!
Blew it! These Ferodo pads are NOT for iron discs. Blinded by the “deal” on EBay. Looking for something else....... plain FDB342 or EBC FA016.
« Last Edit: March 29, 2020, 07:44:39 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #142 on: March 29, 2020, 04:22:07 PM »
Got a couple of quiet hours in the shop this afternoon. Tested a pair of mirrors I thought might work, and discovered one of the clip on bars was loose! Did an end to end bolt check and found a few more! I want to use an early K0-1 small tail light, but the only one I have in my “inventory” has no lamp socket? It’s not a Stanley, but rather a cheap replica. It came with a parts lot I picked up with one of my bikes. Looks like the socket may have snapped off, and it got tossed aside. I had a few old trailer lights in a bin, so riveted in a suitable replacement. Spliced and soldered in a 4 prong trailer connector. The lamp mounts to the rear of the Rickman seat tail. I want to be able to disconnect and lift off the whole thing.
Pulled the airbox off and carefully removed the K6 fuel hoses. They are tee’d for a single hose. The Rickman uses twin petcocks. I didn’t want to damage the carb connector pipes and “o” rings, as nothing was leaking. Installed new hoses and trimmed to fit alloy tank. The tank had a hard life on the race bike, but is super clean inside, straps on easily, and weighs very little. Perfect for the test build and first ride. My Club is planning a Track Day for vintage bikes, in a couple of months. Probably run it then (Covid19 Permitting!).
« Last Edit: March 30, 2020, 05:57:14 PM by BenelliSEI »
Offline smcgill
« Reply #143 on: March 29, 2020, 09:06:23 PM »
    These were  recommended by Vintage Brake for the application.[iron rotors]. I spun the rotors in the lathe and dressed them with 80gr. flapper wheels, cleaned with alcohol. I'm using a 11mm front master.First run today, 2 finger brake with good feel.  Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Offline BenelliSEI
  • 1969 cb750
« Reply #144 on: March 30, 2020, 06:15:06 AM »
Scott........ Well done! Bike looks amazing! Gives me energy to push forward. Thanks!
Found some pads locally today. EBC FA016.
« Last Edit: March 30, 2020, 02:57:39 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #145 on: March 30, 2020, 05:44:44 PM »
Scott’s picture reminded me I needed a place to hang a lic. plate. Made up a flap that hangs out at the back. Finished the taillight while I was at it, cut through the f’glass for wiring and added a trailer plug connector for the tail light. Now seat, plate and light can easily be removed, away from the bike. By the time I made a template, cut the aluminum, drilled, trimmed, polished, bent, soldered wires, shrink wrap, etc..... it was dark!
Also wasted some time swapping over the rear turn signals, left to right. They worked fine but the orange one was plugged into the blue wire and vica-versa. Thought it was OK, but every time I looked at the connections.......... Aaaargh. Honestly, why do we do this? Pictures tomorrow.
« Last Edit: March 30, 2020, 05:55:46 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #146 on: March 31, 2020, 12:38:32 PM »
Finished the back end. Tested the “race tank” with fuel. No leaks and the petcocks work well. Cut a new gasket for the Monza cap and it’s good to go. Searched around for rubber cords to strap it down and finally found a use for the large oil filter “O” rings! Four of them worked perfectly!
I got an original rear rim with the bike (Boranni WM3/ 2.15 X 18” 40 hole). It’s cleaning up nicely and since the weather here is a few weeks off from a “test ride day”, I’ll tear down the back and install it next. Looking for an orange rattle can that closely matches, and hope to change up the yellow front fender too. Will have to get a side stand on before any rides..........
« Last Edit: March 31, 2020, 12:40:13 PM by BenelliSEI »
« Reply #147 on: March 31, 2020, 02:25:11 PM »
Have you researched that gas tank much?  If it could be documented to a known race shop, would be superior to the standard Rickman tank in looks, desireability, function and value.  That thing is fabulous...whoever made it.  I would paint it mostly matching orange with a polished aluminum section.
Offline hondaron
« Reply #148 on: March 31, 2020, 03:46:43 PM »
Looking good, you've been busy 😊
Offline BenelliSEI
  • 1969 cb750
« Reply #149 on: March 31, 2020, 04:37:22 PM »
Thanks for the encouragement!
Sean...... the tank WAS gorgeous at one time. I polished it up and it is brilliant, several baffled compartments inside too. Unfortunately, you may have noticed no shots of the other side. It’s hammered and beaten on the LHS. There are actually skid marks across the top, and it’s been welded up a few times.
Ultimately, I have a ‘glass original that will be painted to match. I have to agree with you though, I may cut the bottom away and see if I can repair the alloy tank, after a summer of riding! It does look great.
