Author Topic: 1974 Rickman Honda  (Read 48974 times)
Re: 1974 Rickman Honda
« Reply #150 on: March 31, 2020, 05:38:14 PM »
Was the tank made here , maybe Curtis ?
« Last Edit: April 02, 2020, 06:52:55 PM by 754 »
Offline BenelliSEI
  • 1969 cb750
« Reply #151 on: March 31, 2020, 05:52:28 PM »
Frank..... May well be. It must have been gorgeous on day 1. It’s definitely made for this bike, fits the frame perfectly. Next time I see the previous owner, I’ll ask. I know he changed over many years ago, when the race clubs stopped allowing glass tanks.
Offline BenelliSEI
  • 1969 cb750
« Reply #152 on: April 02, 2020, 04:46:21 PM »
So today I went to my local Honda dealer to pick up parts. Super, small place, owned by two brothers. It’s closed, but my parts were sitting on the bench, outside when I arrived (they watched me drive in). Next, I went to the Canadian Tire Store. Placed my on-line order yesterday, they picked it and walked it out to me, when I called from the parking lot. Covid responses that are working. Was riding my 2008 Kawasaki KLR650, smiling all the way home. Had a quick lunch, headed off to the shop to. spend the afternoon on the Rickman Project........
As I got down to there, neighbour pulled in with his small stock trailer. “None of the lights are working”. Ended up rewiring virtually the entire thing, took all afternoon. Oh well, maybe tomorrow!
« Last Edit: April 03, 2020, 06:05:25 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #153 on: April 03, 2020, 11:45:04 AM »
Correct brake pads today and polishing up the original Borrani rear rim. Going to lace it in next. The race bike has Buchanan stainless spokes, so after I polish up the spool hub, it should look better!
Offline BenelliSEI
  • 1969 cb750
« Reply #154 on: April 05, 2020, 05:02:07 PM »
Sick of polishing the original, rear Borrani rim, so pulled the yellow front f’glass fender and started prepping for paint. I have three different rattle cans of orange (including a couple of Testor model paints!) and one of them (Armour Coat) that is really close. Too bad it’s so cold out side, got sh*t for stinking up the house and that was just the primer!
« Last Edit: April 06, 2020, 07:05:48 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #155 on: April 06, 2020, 05:33:44 PM »
The excellent weather means we have a lot to do around the farm (hobby/retirement farm), and my “Boss” has a long list of chores. Truthfully, we are a month ahead of schedule here, but really enjoying being outdoors on our 97 acres. Makes it easy to isolate and stay home. A cautious visit to the post office today was the first time out in two weeks!
In order to keep my shop projects moving along, I’ve always push to have to at least ONE item started or completed every day. Not always possible, but I did manage a light sanding and base coat on the front fender today....... not much, but a little.
« Last Edit: April 06, 2020, 08:40:34 PM by BenelliSEI »
« Reply #156 on: April 09, 2020, 10:05:58 AM »
 Are you putting a ski on the front today... Rickman Snowbike .. :o
Offline BenelliSEI
  • 1969 cb750
« Reply #157 on: April 09, 2020, 02:41:10 PM »
Frank..... unreal! Woke up to 2” of snow this morning. 3 km. east of here, nothing! +5C, so it’s all melted now.
Spent the afternoon in the shop. Mounted the orange fender and only a small nick...... Pulled the rear wheel, stripped off the new tire. I want to swap out the DID rim for the original Boranni. The old rim polished up nicely, and it matches the front. Started cleaning up the rear hub, which lead to popping one bearing, caps off and repacked. Everything else seemed good. Now I have to clean and polish 40 spokes! Making progress. Wishing for better weather. Sooner or later I have to build a temporary mount for the side stand so I can take this machine to a ride!
« Reply #158 on: April 09, 2020, 05:12:11 PM »
Does it have a rear  footpeg mount hoop on the frame  ? If you can find a hole in the frame , you can make a t stand to hold it up.. I stuck mine in the end of a knurled footage I mounted into stock mount.
 I can draw a diagram..  I would stick t stand in my pocket to ride the bike.,
Offline hondaron
« Reply #159 on: April 09, 2020, 07:15:22 PM »
Back in the day, when we were Roadracing and cut off the side stand mounts, we'd use a bolt on kickstand similar to this made by rocky cycles in the 70's when we ended up putting bikes back on the street . 😊
https://www.lowbrowcustoms.com/products/british-standard-triumph-universal-clamp-on-kickstand
« Last Edit: April 09, 2020, 07:18:02 PM by hondaron »
Offline smcgill
« Reply #160 on: April 10, 2020, 07:29:52 AM »
John, Did you happen to see any #'s on those bearings? I've tried to source them by size [11/16 I.D. x 2" O.D.] , and also by application, with no luck. It would be my guess that they may fit some other Brit. application but I don't know what.
                                         Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Rickman CR750 [project in progress]
Offline BenelliSEI
  • 1969 cb750
« Reply #161 on: April 10, 2020, 08:32:02 AM »
Scott...... no, I just cleaned up what was there and repacked one. The Rickman Owners’s have a Facebook page with a pretty international participation. Why not join them and ask the question? I’ll check my files for info.
Ron and Frank...... both good ideas, I think I’ll combine them. I have the “post” and a side stand. The previous owner kept most of the bits they cut off. I think I’ll braze it to a split 1/2 tube so I can move it around with a few hose clamps, until I’m satisfied with the location. Then weld it in place. Probably a few tacks for now, then permanently when I strip it down next winter to have the frame plated again.
Offline hondaron
« Reply #162 on: April 10, 2020, 08:46:03 AM »
Pretty cool, that after all these years, you have all the original tabs that were removed😊
Amazing 😊🙏
« Reply #163 on: April 10, 2020, 09:02:15 AM »
I would stay away from clamp on, it scars the frame, and in the end you weld it.
 Hose clamps to set it up should be ok.
Offline BenelliSEI
  • 1969 cb750
« Reply #164 on: April 10, 2020, 09:55:18 AM »
Frank...... that’s the plan, just to set location and angle. I have a friend whose Dad worked for British Oxygen all his life, as an instructor. The guy brazes like the rest of us walk...... trying to talk him into a “physically distanced” visit.
Offline smcgill
« Reply #165 on: April 10, 2020, 02:48:56 PM »
  Thanks John, good information.
  The original stand was attached to a half section of tube,then it attached to the frame, just as you are talking of doing. Maybe you can see in this picture.
  Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Offline BenelliSEI
  • 1969 cb750
« Reply #166 on: April 10, 2020, 04:09:01 PM »
Great photo Scott, much appreciated. Here’s a photo of the bits I have. I’ll replicate the original and stick it back where it belongs. Thanks!
Offline BenelliSEI
  • 1969 cb750
« Reply #167 on: April 10, 2020, 06:04:56 PM »
This rear wheel is turning into a career! Polished the original rim. After pulling off the DID rim that was on the race bike, had to polish the spool part of the hub. Checking bearings created a side bar. Then the sprocket carrier needed a polish. Now the sprocket looks greasy and filthy.......
Laid everything out, ready to lace in the rim. I think the DID rim was on a set of stainless  Buchanan spokes. Large diameter, look good. Cleaned and polished up one spoke, brushed clean the threads, added a drop of lube they sent me years ago. Sweet! 39 more to go......
By the time I finish lacing and truing this rim, remount the tire, balance and get it back on the bike, I’ll have spent most of the week’s spare time, getting back to where I started.
What do other people do?
« Reply #168 on: April 10, 2020, 09:09:52 PM »
This is how I mounted the kickstand to my Seeley. The part is carved out of 5/16 steel, and attaches with the rear engine mount bolt. Since the Seeley was set up to use all the stock Honda parts, including the foot pegs, there is a pin that locks the mount from rotating under the head of the bolt.
BTW, I had one of the clamp-on stands on my '53 BSA, and I couldn't tighten it enough to keep it from folding up with any weight on it.
« Last Edit: April 10, 2020, 09:18:35 PM by scottly »
Offline BenelliSEI
  • 1969 cb750
« Reply #169 on: April 11, 2020, 06:33:53 AM »
Scottly....... that is a really slick installation. Next time I’m in the shop I will be having a good look at my options. Thanks!
Offline BenelliSEI
  • 1969 cb750
« Reply #170 on: April 11, 2020, 02:08:01 PM »
Front fender with a nice paint match, for now. Ultimately (when a new fairing gets fitted) all the glass will get a fresh coat next winter. Painted a headlight bucket too, not sure I like the extra colour. The black one looks better, and ultimately will disappear in the fairing.
« Last Edit: April 11, 2020, 02:10:02 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #171 on: April 11, 2020, 02:12:19 PM »
Finished all the hand polishing, including 40 spokes! Went together smoothly until I realized I swapped sides! 20 longer ones go on the sprocket side and I have them switched....... SH*T! Next time.
« Last Edit: April 11, 2020, 02:16:23 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #172 on: April 14, 2020, 05:09:56 AM »
Got the rear rim built and mounted the tire, yesterday. Balance it up today, and get it back together. Pics later.
« Reply #173 on: April 14, 2020, 06:42:50 AM »
I like that calender, April especially!
Mine on the kitchen wall, wife like it too.
Offline BenelliSEI
  • 1969 cb750
« Reply #174 on: April 14, 2020, 11:24:51 AM »
PeWE........ wondering how long it would take you to spot it! Cheers, John D.
