Author Topic: 7A carbs: correct "T" fuel connectors  (Read 699 times)
Offline 34barab
« on: January 13, 2020, 04:37:54 PM »
Bought a set of 7A carbs supposedly from 71 CB750K1.  While going through them, found some discrepancies.  First attached pic shows the T's from the 7A (1971) carbs.  One T takes two o-rings and one takes four.  Both have 5 mm ID.  Partzilla schematic shows two o-rings per T.  Parts book for 1969 shows same.
Second pic shows T's from 7A on the left, and the T from 064A carbs (1973) on the right.  ID of the 7A is 5 mm, 064A is 4 mm.
What is correct for the 7A - two or four o-rings per T?
Is 5 mm ID correct for the 7A? T from later carb has 4 mm ID.
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
Offline my name is nobody
  • I like Pontiacs and Hondas
Re: 7A carbs: correct "T" fuel connectors
« Reply #1 on: January 13, 2020, 08:04:30 PM »
I've never measured them, but the tees in my set of 7a have 4 o rings, and as far as I know,
they are factory correct.
Offline WhyNot2
  • I'm finally an
« Reply #2 on: January 14, 2020, 05:10:30 AM »
I have both sets of carbs and they both have the 4 o-ring setup.
Offline Doobie
« Reply #3 on: January 14, 2020, 05:51:30 AM »
I've disassembled several sets of carbs and the only Ts I've seen take four gaskets.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
