Could someone with a 75 or a 76 measure the length of the upper brake hose please?
I want to replace my brake lines and I believe I have a 77 hose that was meant to accommodate later, higher bars (I have early, low bars). 4into1 sells a kit that has a 350mm upper hose, but according to what I can gather on Webike in Japan, there was a 300mm and a 350mm upper hose. If that's the case, wouldn't the 350mm hose be for the 77 bars?
Thanks.
