Author Topic: Will a JTF338 16t front sprocket work on K7 750  (Read 3238 times)
Re: Will a JTF338 16t front sprocket work on K7 750
« Reply #25 on: February 07, 2020, 02:55:43 PM »
the reason you need a sprocket with one flat and one shouldered side is not for chain alignment...it is because a sprocket with both sides shouldered is overall too thick for the retaining bolt to tighten up on the shaft correctly.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #26 on: February 08, 2020, 07:52:23 AM »
This is also true. I have used an early 530 sprocket with the double shoulder and had issues with the retaining bolt coming loose. The washers under the head nuts are 2mm thick and I was able to use one of them behind the retaining bolt to fill the 2mm void to mitigate that problem, but the single shoulder 650 sprocket is a better solution IMHO.  8)
Wilbur, you are correct: the flat side faces out. :-[ I checked my original K7 sprocket and it's also stamped on the flat side. I measured both ways and compared to my K1 to verify. Perhaps the shoulder side faces out when installed on a 650?
That's part what makes this forum such a valuable resource. Many of us have experienced one or more of the issues presented and hopefully as a collective can sort things out, even if it takes a couple of tries!  ;)  ;D  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
