Author Topic: 1978 750k Crankshaft and rod bearing journals measurements  (Read 355 times)
Offline crxnug
« on: January 19, 2020, 05:38:17 PM »
Im rebuilding a 1978 Cb750k , I need to replace crankshaft bearing and rod bearings, Im going to have to measure the crank and rod journals . does any know what the measurement should or could  be and bearing color code or part numbers for the measurements, any help would be much appreciated
Re: 1978 750k Crankshaft and rod bearing journals measurements
« Reply #1 on: January 19, 2020, 06:14:59 PM »
If you have my book....;)
But, if you don't: use Plastigage on them in the cases and judge the new shells you need by the clearance.
« Reply #2 on: January 20, 2020, 07:40:36 AM »
Pretty much any manual including Hondaman's will explain the process and have a selection chart using the case markings/stampings and crank etching for the mains and rod labeling and crank etchings for rods but you need to have a good eye for these "etchings". Most folks will use these and purchase the appropriate shells then Plastigage them. You can download a Honda Shop Manual from this site. I haven't looked at Hondaman's book but I hear it is very user friendly.
