Author Topic: Leaking new Honda petcock? CB750 K5  (Read 1033 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: January 21, 2020, 03:28:44 PM »
Bought a new Honda petcock from the dealer for my CB750 K5 and after I installed it, it seems to allow gas through the line when in the OFF position. No gas on the outside at all - just doesn't quite stop the flow. Anyone had that issue before?
Edit: Genuine Honda petcock, screw-on type, not the type w/ 2 screws.
« Last Edit: January 22, 2020, 01:09:24 PM by Tugboat »
Offline CaptFatCat
Re: Leaking new Honda petcock? CB750 K5
« Reply #1 on: January 21, 2020, 03:45:03 PM »
I have had this happen on a aftermarket petcock. The quick fix for me was to tighten the screws on the valve base and Presto!
Resurrecting a Herman Munster CB750 from a few old baskets of K2 and K7 parts.
Offline Johnie
« Reply #2 on: January 21, 2020, 04:36:57 PM »
If the 2 gaskets on the screws that hold the petcock to the bottom of the tank are old or the screws are loose you will have this condition. I had it happen on my KO and took the fuel bowl off and put a cup under the petcock. It leaked a drip every 5 seconds with the fuel coming from around those screws. Installed new gaskets and no more drips.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #3 on: January 21, 2020, 04:51:28 PM »
Yes and thin generic fibre washers dont work, Honda ones are expensive but a lot thicker
Offline CaptFatCat
« Reply #4 on: January 22, 2020, 04:58:19 AM »
Its not leaking from valve to tank right? Its leaking through the valve in off position right?
Remove the 2 small screws on each side of the on/off lever to expose the valve and you will find your problem inside.
Easy fix.
« Reply #5 on: January 22, 2020, 05:10:08 AM »
If its actually a K5 its not held on by 2 screws with fiber washers etc. but is mounted on a threaded bung hole. Either the poster is putting the handle in the wrong position to reserve or it has a problem internally. Is the a genuine Honda petcock or an aftermarket ??
Offline Johnie
« Reply #6 on: January 22, 2020, 10:35:15 AM »
Thanks Eric...shows how many K5's I have done  ;D
Oshkosh, WI  USA
« Reply #7 on: January 22, 2020, 11:03:56 AM »
  A K5 would be way too new for your Johnie !!   ;D
« Reply #8 on: January 22, 2020, 11:43:15 AM »
Try turning the filter/tube 180*
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #9 on: January 22, 2020, 01:08:49 PM »
 Genuine Honda petcock, screw-on type. Yes, fuel passes through the valve in the OFF position but there is no fuel leaking externally.
« Reply #10 on: January 22, 2020, 02:23:44 PM »
I had a new [Kawasaki Z1] petcock leak, I called and complained and they sent a replacement.
Been good ever since...
« Reply #11 on: January 22, 2020, 03:40:13 PM »
We never had K5 in UK went straight from K2 to K6 so have no knowledge of the screw on type but if it is new genuine Honda send it back
Offline Spanner 1
« Reply #12 on: January 22, 2020, 09:27:15 PM »
My K1 750 petcock is also passing gas when 'off' . I thought it was the fiber washers ( it's a 2-screw mount ). New Honda washers and screws and it still passes gas when off. I guess next is a new 3-hole washer in the petcock, 'prolly destroyed by corn gas ! It's about 2 years old.
Online Don R
« Reply #13 on: January 22, 2020, 09:47:33 PM »
You might try removing the cover plate and flipping the washer over, sometimes this works.
