Early comstars are not tubeless. They will hold air if you can find a valve stem that will seal the hole properly, but the bead section is not constructed to retain the tire in the event of a flat, so you would literally be risking your life to run these rims tubeless at road speeds. I think you should look for a set of Lesters that have the "TL" stamp next to the d.o.t. stamp. These should have the extra rib cast in, inside that keeps the tire from separating from the bead.
