Author Topic: 73 Cb500-4 clutch rod?  (Read 659 times)
Offline Gary73Cb500-4
« on: January 25, 2020, 04:44:35 AM »
Hi all I'm an old guy with an old b like that I got about 15 years ago. I striped out the bike and have been doing parts clean and rehab slowly. Question is can I pull out the clutch rod from the drive side without something falling out on clutch basket side? I couldn't find out in the parts diagrams. I want to replace the seals . Oh it is a 1973 Cb500 4 got  free with title. Been reading posts for a long time finally joined. Thank for all the good inspiration guys.
Offline Scott S
Re: 73 Cb500-4 clutch rod?
« Reply #1 on: January 25, 2020, 05:42:37 AM »
 Yes, you can pull it out. You may find that it is in two pieces; it's supposed to be one long rod. There is a ball bearing in the clutch lifer on the LH side cover/sprocket cover. Don't lose it. It may be a good time to clean and regrease the lifter assembly, too.
 Order two of the seals. Remove the old seal. Use a pocket knife or similar to *lightly* chamfer the case where the old seal was removed. Just enough to remove any sharp edges or burrs that may catch the new seal. Install a thin smear of Yamabond or similar (NOT silicone RTV) on the new seal and tap into place using a socket that fits the diameter of the new seal. Make sure it's square or flush.
 Lightly sand the pushrod with some very fine sandpaper if you feel any burrs on it. Reinstall and check clutch adjustment.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #2 on: January 25, 2020, 08:01:25 AM »
Just to add get a new, preferably genuine, clutch cable and get the routing correct to get a light(ish) operation and YES it is worth the extra for a genuine cable
Offline Deltarider
« Reply #3 on: January 25, 2020, 08:47:30 AM »
I agree 100% wit Bryan. Question is... is this one genuine or not: https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_22870323621P/
Is it identical with this one or is the CMSNL the only real genuine one? https://www.cmsnl.com/honda-cb500k2-general-export_model50441/cable-clutch_22870323621/#.XixqMCPvK_g
Quite a difference in price.
But... please realise US models that have the higher handlebars need:
https://www.cmsnl.com/honda-cb500k2-four-1973-usa_model461/cable-clutch_22870323020/#.XixtLyPvK_g or from DS: https://www.davidsilverspares.com/parts/by-part-number/part_22870323020/
With this one prices are much closer.
Maybe I need a new cable myself. I will definitely have the genuine one. It is very good. But come tomorrow I will first remove the non stock Dyna coils temporarily, just to see if it is maybe them that hamper the proper clutch cable operation by being in the way because of their ridiculous size.
CB500K2-ED Excel black
« Reply #4 on: January 25, 2020, 09:55:51 AM »
If the Silvers one has a P at the end it is pattern. If you are in US try one of the online dealers first
Offline Deltarider
« Reply #5 on: January 25, 2020, 10:19:32 AM »
Thanks Bryan, I was confused by this text: ***OEM*** CLUTCH CABLE
« Reply #6 on: January 25, 2020, 11:21:08 AM »
Thanks guys just wasn't sure about another ball in clutch basket side. Scott I did pull the adjustment mech. I had to press it out , polished it greased and powder coated the cover that side was nasty.
« Last Edit: January 25, 2020, 11:47:45 AM by Gary73Cb500-4 »
Offline Deltarider
« Reply #7 on: January 25, 2020, 11:48:02 AM »
« Reply #8 on: January 25, 2020, 11:53:52 AM »
Welcome Gary.  Those push rods are prone to breakage, they changed the setup when the 550 was engineered and manufactured.
You should start a thread in "Project Shop" area so we can follow along and answer any other questions you may have.
Here...   http://forums.sohc4.net/index.php/board,103.0.html
« Reply #9 on: January 25, 2020, 01:57:42 PM »
Thanks for the link Deltarider and Steve-O for the welcome doing a project thread would probably keep me motivated too. This is the bike I'm working on . I do my own powder coating on the small things in my home built oven. The frame is out for coating at a real powder coating place as of yesterday. Should have built the oven motorcycle size instead of bicycle sized. Done so far seat, electrical,  form with bars and controls , small parts refurbished and most parts ordered. Still need to break down the wheels to coat rims and hugs and put top end on motor. Oops on the photo orientation!
« Last Edit: January 25, 2020, 02:00:27 PM by Gary73Cb500-4 »
« Reply #10 on: January 26, 2020, 05:42:24 AM »
I had been a member I thought about 10 years ago but couldn't remember my user name or password so I just signed up again....gotta document stuff better!  I just remembered it the use name anyway it XC204 so if I can recover my original pw I'll continue this build thread.
http://forums.sohc4.net/index.php/topic,101767.0.html
Offline Scott S
« Reply #11 on: January 26, 2020, 06:33:17 AM »
 Even if you can't recover your old password,  go ahead and update the build thread. We'll know it's you!
'71 CB500 K0
'81 Yamaha XS650
