Author Topic: Pics of engine removal please  (Read 2123 times)
Offline tlbranth
« on: February 07, 2020, 05:55:12 PM »
I've pulled the engine on my 750 3 times now. The first 2 times I manually lifted it out (why I have a bad back?). The third time I saw a thread on here which showed a frame the guy made which, when hooked to a comealong, hoisted the thing enough to get it out> There was also a thread showing how to strap the engine to such a hoist. I welded up the frame and I followed the strapping technique. It worked. I now have to pull the engine again. I have the frame. I can't find the strapping technique and I'm too f#$%^ng old to lift the bastard out myself. So if anyone has hoist pictures. I'd love to see them.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline XC204
Re: Pics of engine removal please
« Reply #1 on: February 07, 2020, 06:48:44 PM »
Hi on the 3rd and 4th post of my build thread http://forums.sohc4.net/index.php/topic,101767.0.html I have pictures of the hoist fixture I made my own version of one I saw on the  site  the original was plasma or water jet cut and very nice but I just cied the basic shape the first picture shows it strapped to the motor. Good luck and don't get hurt. Oh the white on the lifting jig is stick on sand pa Dr so the straps don't slide around.
« Last Edit: February 07, 2020, 06:54:17 PM by XC204 »
Offline Dimitri13
  • 1974 CB550K
« Reply #2 on: February 07, 2020, 07:20:32 PM »
For me it was easier to remove the frame from the engine than it was to remove the engine from the frame.
Lay the frame and engine on its side (remove forks and rear wheel), unbolt the frame bolts, then just pull up the frame. Reverse steps for installation.
« Reply #3 on: February 07, 2020, 10:22:46 PM »
If bike has frame kit, head and cylibder can.be removed when still in frame making it easier to lift the bottom end wirh a strap and swing it out of the frame.  Reverse order when back in.
I have had thoughts about using a lobg steel bar/profile the engine is strapped to. It rest on a jackstand on one side, the other side a jack pumping it up until engine is free. Bike to be moved sideways since it is parked on dollies. 2 for wheels, 1 for side stand. The equipment do not take much space when not used.
There are also L shaped lifting device of wood or metal with straps. This need a lift or crane. Maybe a car engine lift can do that.
Offline pjlogue
« Reply #4 on: February 08, 2020, 12:55:51 AM »
Funny how the earth's gravitational pull gets stronger as time passes!  ;)  I too found that pulling the engine was more than I could handle by myself when I restored my 750 several years ago.  I did what Dimitri13 did.  Laid the bike down on the right side with front forks removed and rear wheel removed (also tank and side covers) and used straps to suspend the frame as I pulled it off the engine.  I put down a lot of padding to protect the engine cases.  When I went to reassemble the bike I used a 2x4 strapped tightly behind the jugs with the cam chain tensioner removed.  2x4 was long enough to allow jack stands to support the engine.  One jack stand on right side of engine, one on left side and one on far left side with frame suspended between the two left jack stands.  Again, forks and rear tire removed.  Both engine removal and replacement are doable by one person this way.I got the 2x4 idea from youtube Hack a week.     Just make sure the 2x4 supporting the engine is parallel grain and no knots so it dosn't snap!
-P.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: February 08, 2020, 08:12:55 AM »
LOL! I feel your pain, I'll be 57 this year and a career in construction takes it toll on the body. I use simple 1" wide nylon straps rated for at least 300lbs. I tie a simple overhand knot in each end to create a loop on each end. I slide each strap over each side of the engine making sure the strap passes inboard of the crank bolts so they don't slide off. Adjust the length of the strap by untying and retying the knot in one of the end loops until you get it where you want it. My strap length puts the lifting fixture pretty much even with the carb inlet spigots. I tie the strap closest to the lift about an inch shorter to cant the engine ever so slightly to get over the engine mount on the lower right side. I can start with a fully assembled bike and have the engine out in about an hour and a half. The hardest part is attaching the legs to the hoist!
http://forums.sohc4.net/index.php/topic,58210.msg1684742.html#msg1684742
This thread has a couple more pictures:
I will usually remove the bracket from the back of the crankcase that holds the carb overflow tubes since the clearance is so tight this little bracket often gets in the way and can be easily mangled.  8)
To keep track of the straps I store them with the lifting fixture. EZPZ  ;D
« Last Edit: February 08, 2020, 08:15:24 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #6 on: February 08, 2020, 08:48:30 AM »
You can pull and mount engines like a pro.  Bikers lines up with their bikes and engines out or in quick and painless ;)
Offline tlbranth
« Reply #7 on: February 08, 2020, 09:10:24 AM »
Thanks guys. Madm - that's what I needed to see. Any luck the thing comes out this morning.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline johans
    • corporate leather
« Reply #8 on: February 08, 2020, 09:16:10 AM »
this is my contraption , these are the only pics i have of the frame to install the motor . Once i have it off the hoist  i take the right side  ( facing the bike ) beam off , pass the motor through the frame and reattach the beam & maneuver the motor in place .  Much easier this way than laying the bike on its side ( with wheels off , when i use to do it that way  ) .  Last motor i installed my wife was my helper , not too difficult .
Same here - original idea was from HackAWeek  youtube video
« Last Edit: February 08, 2020, 09:31:54 AM by johans »
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
Offline Doobie
« Reply #9 on: February 08, 2020, 10:38:46 AM »
The most expedient way for me was to put the bike on its side and lift the frame. I would have loved to use some kind of rigging because I have a bad back but I couldn't figure out a way to do it in my garage. It comes out from only one side but can't remember whether right or left (I'll take a guess and say left but someone needs to check me  ;D).
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline rotortiller
« Reply #10 on: February 09, 2020, 06:17:21 AM »
This worked for me.
Offline kerryb
  • Not a very
« Reply #11 on: February 09, 2020, 07:12:20 AM »
« Reply #12 on: February 09, 2020, 07:16:41 AM »
Stripped frame around engine is easy during a complete restore.
Different on a complete bike no need of taking all off for pulling the engine only to fix it.
The lifting devices some have built is a grate help to pull engine without collateral damage on bike or person. Possible without help.
I pulled engine many years ago by laying bike on its side and lift rest of the bike from the engine that sat on its side on the garage floor. I think  I used wooden planks it landed on.
I had to adjust cam.
Same way back. It is easy to add some extra scratches that way.
A soft carpet covering the fllor help.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #13 on: February 09, 2020, 07:25:57 AM »
Wilbur has a nice set of plans for an engine hoist. I’ve only used it once, but worked like a charm.
Offline rotortiller
« Reply #14 on: February 09, 2020, 07:26:47 AM »
Just pull the swing arm assy and front end assy to lighten the tank up a bit.
Offline kerryb
  • Not a very
« Reply #15 on: February 09, 2020, 07:28:36 AM »
I use the c-hook method with a harbor frieght electric winch bolted to the roof rafters, this gives me 10' of cable between the engine and the winch.  Combined with the fine height adjustment provided by the HF lift table, I can pull the engine  and have it on the stand in 1/2 hour to adjust the valves with the valve cover off, which I prefer to do than struggling with bent feeler gauges through those tiny little holes!
Another 45 minutes to put it back in the bike without scratches and hook up the parts is a good nights work, keeps me out of trouble!
Offline tlbranth
« Reply #16 on: February 09, 2020, 06:09:55 PM »
Thanks for all the help. I got the engine out without any problems. Here's a picture of the setup. I built a trolley & rail and mounted it on the beam in the garage to move the engine out from the frame. I'll be using it on other parts of this project too. It runs on 2 old rear wheel bearings.
« Last Edit: February 09, 2020, 07:16:53 PM by tlbranth »
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #17 on: February 09, 2020, 07:06:43 PM »
Thanks, TL! I feel better now, knowing that I am not the only one who saves those old bearings that wore out, just to use them on something else... :D
Offline kerryb
  • Not a very
« Reply #18 on: February 09, 2020, 07:39:57 PM »
That's a nice set-up, I'm a little jealous.
« Reply #19 on: February 09, 2020, 09:20:03 PM »
Good tool! A mini version with tripod pipes on each side of the bike, an upper beam holding togerher where the lift is gliding. Balanced C beam included. The entire package will not take much spase when.folded together/ taken apart. It would be fine if it can be used for something else. It must be something like this to buy cheap, ev only the engine balanced beam to make.
I need to make a good lift when.testing my K2 engine build in my stock K2 for road test, initial break-in and dyno. Engine out again and in with the.stock engine that might have got another cylinder with fresh tight bores and +0.5mm K7 pistons .
Old bad ball bearings can be taken apart, one of the races placed on new bearing when tapping it in place. Inner race for shaft, outer for cases, hubs etc.
« Last Edit: February 09, 2020, 09:22:27 PM by PeWe »
« Reply #20 on: February 10, 2020, 06:08:55 AM »
Suhweet! And you don't have to strip the bike to the frame!  8)
TAMTF...
Wilbur
Projects:
Offline pmanning
« Reply #22 on: February 10, 2020, 08:00:00 AM »
I've been following this thread with great interest. Back in the seventies when I was in my twenties pulling the engine on a 750 did not present much more of a challenge than, say, changing the rear tire. Now we're in the twenties and I'm in my seventies and when I pulled the engine last fall for a "freshen up" (last time was 1992) I experience serious concern about how I was going to get that sucker back in. Thanks for all the options.
Offline tlbranth
« Reply #23 on: February 10, 2020, 08:04:32 AM »
Actually, bearings were good. They're the single-seal originals which I always replace. I keep any bearings I take off that aren't a goner.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
