Support the site. Your contributions keep this site running.
... you are missing the D rings on your triple clamp ...
Air forks, and you are missing the D rings on your triple clamp. Best get them in there before it breaks.
Those are as mentioned air fork adapters. Often they are tied together. We used to swap in a fork seal that was a mm smaller ID. Suzi dirt bike I think. Frank mentioned the D washers, they go in the gap of the top triple to keep the aluminum top tree from breaking when tightened. One of my bikes still can't draw tight even with them so I snug the bolds with the washers still loose and Loctite the nuts.
You can just unscrew the aftermarket fork caps and replace them with the stock caps.The cracked triple is a major concern...
The triple tree is a JDM type with the speed indicator light hole .. does your other have the hole ? NORTH American bikes came without the hole. JDM = Japan Domestic Market.
Not sure about the numbers, but the date on the title back then was based on the sales date, not the actual model year. Honda got busted for selling earlier bikes as the current models...Do you have stock caps?
Thank you. Yes, no worries I have a spare. My son just bought this bike. The title says 1972 but the Frame #1120xxx and Engine #1130xxx tells me it is a 1971 K1, am I correct?
There's some info on the JDM bikes in this thread:http://forums.sohc4.net/index.php/topic,136534.msg1538826.html#msg1538826Fixed pegs, different top triple and sidestand, no VIN tag, km/h rather than mph plus a few other things.
