Author Topic: CB650 Engine rebuild  (Read 704 times)
Offline Jbosma
« on: January 26, 2020, 01:44:49 PM »
OK so I've been working on doing a top end rebuild for my 1981 CB650 and im on the installation now. Im currently having an issue where I can't get the cam sprocket on the shoulder of the cam shaft where it needs to be. I have the cam chain tensioner bolt torqued down to 10ftlbs as per the manual and I can even get the cam shaft seated in its journals but can't just get the sprocket (with the chain over on it) over the cam shaft. I pulled out the cam shaft and sprocket from the engine just to see if it does actually go on correctly and it certainly does go on this cam shaft shoulder and fits very nicely when I have it out off the engine.
thoughts?
Offline scunny
  • don't call me expert
Re: CB650 Engine rebuild
« Reply #1 on: January 26, 2020, 10:14:54 PM »
With a new cam chain on my 650, I had the same problem.
step 1. make sure the tensioners lower end is in it's groove, you can verify by having the oil pan off and lying on the ground in my case and shining a torch up.
put chain on sprocket and lever it into position.
check alignment.
I don't know why but, that's the only way I managed. 20,000 KM's later every thing is still good.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Jbosma
« Reply #2 on: January 27, 2020, 06:56:57 AM »
ok ill give that a shot and upload some pictures of the tensioner today.
Offline Jbosma
« Reply #3 on: January 27, 2020, 08:46:22 AM »
So I removed the oil pan and from what I can see it looks like the tensioner is not rubbing against anything and is seated correctly. Its very hard to get some decent photos but from what I got, I think you can see that it is infact not rubbing against anything. So where does this leave me? I've heard of some people sticking a screwdriver down and pushing on the tensioner to release even more tension. Just don't know if thats such great idea and I don't want to break the tensioner, although I do want to get this engine put back together...
let me know what you think from the photos, I also attached one with a view of the entire gear assemblies does everything look good? (I have the strainer removed for cleaning)
Offline DaveBarbier
« Reply #4 on: January 28, 2020, 01:27:31 AM »
I do use a big flat head screw driver to push the tensioner flat to relieve pressure, then tighten the tensioner so it stays put. It does seem like your tensioner is in the right spot so I would lever up the sprocket and chain on to the cam shoulder. That’s what I did with my 550 and 650. You should only have to go up like a couple millimeters.
Offline CB650CPastor
« Reply #5 on: February 01, 2020, 04:45:38 PM »
thoughts?
Man, that cam lobe in the third picture looks pretty knackered. I don't think I would install that.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
Offline Jbosma
« Reply #6 on: February 18, 2020, 07:51:25 PM »
Was able to finally get it in! Using a large screw driver did the trick. Cam lobes looked only rough in the pictures because I had pulled it out of the freezer and that was frost on the can shaft.  Can shaft is actually in pretty good shape.
Offline DaveBarbier
« Reply #7 on: February 19, 2020, 05:55:48 AM »
Why was the cam in the freezer?
Offline Jbosma
« Reply #8 on: February 19, 2020, 01:37:58 PM »
Cam was in the freezer because so it would shrink making it easier to fit into the sprocket. Yeah I doubt this actually works but I’ve seen many people do it and sometimes It works out well. Seen it done on a couple cl350
