Author Topic: CB750 K1 Carb Floats  (Read 398 times)
Offline CB750wannabe
« on: February 21, 2020, 03:18:23 PM »
My apologies if there is already a thread...  My K1 came with brass floats.  I'm going to replace.  Question is brass vs plastic - either one better?  Should I avoid aftermarket ones?  I can get brass or plastic through JTMARKS.  Just want to run it by you experts before I decide which to order.  Thanks!
1971 CB750K Candy Garnet Brown
http://forums.sohc4.net/gallery/28485-110112203145.jpeg
1975 CB550 K1 Candy Jade Green
Offline BenelliSEI
  • 1969 cb750
Re: CB750 K1 Carb Floats
« Reply #1 on: February 21, 2020, 03:49:09 PM »
JT sells only quality. Make your life simpler and order plastic......
Offline tlbranth
« Reply #2 on: February 21, 2020, 06:01:26 PM »
If the brass floats are not leaking, why replace them?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Bodi
« Reply #3 on: February 21, 2020, 08:30:04 PM »
Yes, why replace them?
Brass or plastic... no preference. Abused, brass can corrode and leak, plastic does not have that issue. But do you plan on abuse? I've only seen serious corrosion when the bike was left for years with fuel in the tank and petcock on. That concentrates whatever nasty stuff is in that gas that can't evaporate. Presumsbly you wouldn't do that?
I have worked on really old motorcycles... pre 1920... their carbs are primitive but all had brass floats, and some originals were in pristine condition.
Whatever plastic Keihin used for floats, it is impervious to gasoline and ethanol. No ptoblem with them.
Whichever you choose will be fine if OEM. I haven't knowingly encountered aftermarket floats either brsss or plastic Might be great, might be trouble, you call.
« Reply #4 on: February 23, 2020, 05:27:31 AM »
 If doing a perfect restoration/showbike trailer queen then brass or if doing a reliable everyday rider then plastic/foam and forget about that leaking issue ever arising.
