Author Topic: Front brake lever has no play  (Read 4002 times)
Offline Johnny340
Re: Front brake lever has no play
« Reply #25 on: February 27, 2020, 06:11:45 PM »
Are you sure that pad is the correct one and really seated in the caliper??
I thought they were seated correctly but I'll double check when I am changing the rotor.
Sent from my SM-A705W using Tapatalk
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Johnny340
« Reply #26 on: March 05, 2020, 09:44:22 PM »
So the proper rotor is installed now and the pads looked good on the calliper, which is now mounted correctly. The play at the lever is still minimal and if I try to adjust the inside pad further away to create some play, the outside pad just pulls it over and leaves the adjuster bolt sticking out on the inside. Pics below show this as well as the distance the lever moves.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #27 on: March 05, 2020, 09:54:01 PM »
That must be a larger than stock MC..
Offline Johnny340
« Reply #28 on: March 05, 2020, 09:58:11 PM »
I found the bill for the mc.
It’s from vintagecb750  Part #: 08-0253 and is 5/8”.
Is this ok? The braided lines make for a rock hard pull...just not enough travel.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #29 on: March 05, 2020, 10:09:44 PM »
5/8'' (15.87mm) is way too big for a single caliper, IMHO.
Offline Scott S
« Reply #30 on: March 06, 2020, 03:22:55 AM »
 It should be the 14mm version.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #31 on: March 06, 2020, 07:40:16 AM »
Offline Johnny340
« Reply #32 on: March 06, 2020, 09:50:10 AM »
Thank you all! I now know what I need to make it ideal.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline robvangulik
  • Honda Fourever
« Reply #33 on: March 06, 2020, 11:13:12 AM »
Right, a half inch master cylinder ;)
Offline Johnny340
« Reply #34 on: March 06, 2020, 12:14:06 PM »
My Johnson is already a full half inch.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #35 on: March 06, 2020, 09:39:51 PM »
1+ A 1/2" MC should work well with your 42.8mm caliper.
Offline Johnny340
« Reply #36 on: October 12, 2020, 05:58:56 PM »
Just to close this off, you guys were correct (as usual). I installed a 14mm master cylinder in place of this 5/8" one and the difference is huge!  Great modulation now with this smaller master cylinder on my single disc front brake.
Thanks again!
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
