Author Topic: 78 550K overcharging?  (Read 664 times)
Offline 90blacknight
« on: February 25, 2020, 07:51:43 AM »
Hello all,
I started the bike (78 CB550K) for the first time after the mild rebuild and I'm seeing 14.95 volts at around 4500 RPM. I installed a new regulator/rectifier combo unit. The battery is good. When I fully charge the battery I'm getting 12.9 Volts. Is 14.95 volts too high? I can try putting the old OEM rectifier and regulator back on and measure the results.
Thanks!
Re: 78 550K overcharging?
« Reply #1 on: February 25, 2020, 09:25:14 AM »
A lead acid battery will handle that but check fluid level regularly.
Only reason for overcharging is when black wire at reg shows less than battery voltage due to bad connectors
« Reply #2 on: March 08, 2020, 11:38:02 AM »
You were absolutely right! Cleaned up the connectors and voila! 13.4v at 5000 rpm. Thanks!
