If you want to totally eliminate the starter safety system like the K0-K2 had, jump the solid green wire to the green/red wire at the SMSU connector.
If you want to retain the clutch and neutral switch interlocks, you can jump the green/red wire to the light green/red wire, but the neutral light will come on when the clutch lever is pulled in unless a diode is used instead of a jumper.
