Author Topic: Spondon caliper rebuilds/ tools?  (Read 2021 times)
Offline slikwilli420
  • Master of Disaster
« on: March 06, 2020, 06:12:13 pm »
I know this isn't the exact right section for this but where can I find seals and the tool to remove the plug on these Spondon calipers?
Offline spotty
Re: Spondon caliper rebuilds/ tools?
« Reply #1 on: March 06, 2020, 06:38:30 pm »
i blame Terry
« Reply #2 on: March 06, 2020, 08:02:17 pm »
You got what you need to make the tool....
Offline CR750
« Reply #3 on: March 06, 2020, 11:36:04 pm »
Is the left one leaking brake fluid so bad ? Or just spilled when unmounting ?
Worst link ever below.. And don't know the dimensions of the spondon...but you might need this or similair ?
( not to hard to fab either I agree with an old socket en 4 pieces of bar stock and a welder it should be a few minutes )
https://desertcart.co.uk/products/7563798-24-mm-spanner-socket-tool-for-rear-brake-caliper-piston-winder-rewinder-tool-for-honda-acura-car-auto-civic-s-2000-crv-crz-crx-del-sol-accord-cross-tour-fit-insight-odyssey-ridge-line-pilot-element-prelude-from-1984-on-might-fit-others
« Last Edit: March 06, 2020, 11:40:43 pm by cr750 »
W r e n c h  ·  R i d e  ·  R e p e a t
Offline simon#42
  • liverpool
« Reply #4 on: March 07, 2020, 06:31:34 am »
you dont have to remove the plug , and your not supposed to .
« Reply #5 on: March 07, 2020, 06:44:17 am »
Ditto
« Reply #6 on: March 07, 2020, 08:37:33 am »
I thought that was how the pistons came out since it's monobloc?
Any source for seals?
Offline simon#42
  • liverpool
« Reply #7 on: March 07, 2020, 09:02:37 am »
plenty of room to get the pistons out , get the inner out first as it is shallower then the outer . if you try to take the plug out it will damage the threads .the plug  was only needed for manufacture .
as i have told you before these are a very poor calliper . people think they must be strong as they are one piece but in reality they are very weak in the centre and flex a lot . if you want to use them just buy lockheed seals they are what spondon used .
« Reply #8 on: March 07, 2020, 11:32:57 am »
Didn't realize they weren't needed to replace seals so thanks for that. Makes life much easier. These will be on a street bike based on your previous recommendation to use Lockheed calipers for racing. Also nice that they take the same seals.
Offline simon#42
  • liverpool
« Reply #9 on: March 07, 2020, 11:52:29 am »
they will be fine on a road bike they are just not good enough for your race bike , they look good as well .
