Author Topic: My Dad's 1974 CB450K7  (Read 4678 times)
Offline onepieceatatime
« on: March 07, 2020, 01:55:44 AM »
My Dad passed away in May of last year and left me his '74 CB450. He bought it new; Mom and Dad took it on a vacation camping trip to Canada at least once before my sister and I were born. It was the first motorcycle I saw, and he used to give me rides on it when I was little. He last had it on the road in 2014, and parked it after having problems with it only running on one cylinder. I can't remember exactly what he said he thought was wrong with it, but I think he said it was a spark problem. (This would make sense because I found new points and condenser on his work bench.) He never got back to working on it to have it running again.
I drove up to Michigan to pick it up last August, and finally got a chance to start working on it.
There are 5640 miles on the bike.
I started with a little cleaning and polishing, an oil change, and making sure the engine was still free.
It would not quite turn all the way over, so I pulled the spark plugs and looked into the cylinders with an endoscope. Some carbon buildup in the cylinders, and it looked like the intake valve on the left cylinder wasn't closing all the way. I got on ebay and ordered a spare set of front engine mount brackets and built an engine stand adapter.
I put some ATF in the left cylinder with the piston up, and let it sit for a while. I loosened the valve adjuster lock nut and worked the adjuster back and forth a little, and the valve closed as it should.
I adjusted valve clearances.
Even though my Dad was very mechanically inclined, and taught me how to work on vehicles when I was growing up, I remember him telling me that the gentleman who built the bike out of the crate at the dealership is who he always took it to when the valves needed adjusted.
With the valves adjusted, I adjusted the points, and put the engine back into the frame and did a compression test. only 5PSI difference between the cylinders.
I reconnected the carbs and exhaust (with new copper gaskets) and all of the electrical connections.
I put acid into the new battery, and its now on the charger. Once charging is complete, I'll put the battery in and check ignition timing. It will get another oil change also because of the couple of teaspoons of ATF I put into it.
Once ignition timing is set and I get my hands on some ethanol free gas, I'll put the tank back on and try to start it.
« Last Edit: March 23, 2020, 08:51:38 PM by onepieceatatime »
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Scott S
Re: 1974 CB450K7
« Reply #1 on: March 07, 2020, 04:17:55 AM »
 That's awesome. And it looks to be in good shape, too. I love a "survivor" bike. If it sat that long, you're probably gonna end up pulling and cleaning the carbs.
 Man... I want a CB or CL450.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline rocket johnny
Re: 1974 CB450K7
« Reply #2 on: March 07, 2020, 07:01:47 AM »
cool bike and story !    thanx for sharing
Offline Johnie
Re: 1974 CB450K7
« Reply #3 on: March 07, 2020, 09:13:49 AM »
Yah, neat story there. Cool to have your dad's bike and that it will see the road again. Here is a pic of me back in 1974 when I bought my new CB450.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: 1974 CB450K7
« Reply #4 on: March 07, 2020, 02:53:37 PM »
Dad had drained the tank and carbs. I pulled the bowls and jets, they are clean.
I also love a good survivor bike, and plan on only cleaning it up and keeping it mechanically sound. I want it to stay the way Dad always had it.
I'll put new tires on it too, so that I feel comfortable riding it, but it will be a garage queen with only occasional rides.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Re: 1974 CB450K7
« Reply #5 on: March 07, 2020, 02:58:20 PM »
They sure are good bikes. Thanks for sharing the picture.
I don't know if there are any old pictures of Dad with his, but next time I head up to Michigan, if I can remember, I'll look.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Re: 1974 CB450K7
« Reply #6 on: March 23, 2020, 08:42:46 PM »
Well, I put the new battery in the bike, and set the ignition timing per FSM instructions. I drained the ATF contaminated oil, and put fresh oil in, replaced the brittle fuel line and old tank mount rubber with new, and put the tank on. I cranked the engine several times to try to make sure oil was circulating. Then a bit of ethanol free gas in the tank and tried to start it up.
https://photos.app.goo.gl/zBkA6JeqshJYfL5Y8
I let it idle for a few minutes, and it settled in a little under 2k RPM. The right pipe did heat up a little but was running much cooler than the left.
With that I think I may be back to whatever Dad's original problem was, and time for a little more troubleshooting.
« Last Edit: March 23, 2020, 10:33:54 PM by onepieceatatime »
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Pielz
Re: My Dad's 1974 CB450K7
« Reply #7 on: March 23, 2020, 10:11:28 PM »
Very cool! Excited to see more of this bike
https://www.homedepot.com/p/TruFuel-TruFuel-4-Cycle-Ethanol-Free-Fuel-6527238/203571144
This is what I was talking about when I  mentioned getting ethanol free gas at Home Depot. It's only 32 oz and at 6 bucks it's not super cheap per ounce, but good for troubleshooting or test drives if there aren't any ethanol free sources near by!
« Last Edit: March 23, 2020, 10:17:19 PM by Pielz »
« Reply #8 on: March 23, 2020, 10:32:07 PM »
Thanks Pielz.
I found a station in town, I'm not sure when they opened, but all they sell is ethanol free.
I think it was around $2.60 per gallon of 91 octane; I bought 10 gallons.
« Last Edit: March 23, 2020, 10:38:40 PM by onepieceatatime »
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #9 on: March 29, 2020, 12:40:53 AM »
This is a bike to keep as is, let the family history continue ;)
It looks really nice.
If I were you, remove bags and sissy bar for storage to when needed again.
Offline Pielz
« Reply #10 on: March 29, 2020, 09:49:40 PM »
Love it! That's killer that you found a place that sells it.
I smelled ethanol free gas and exhaust for the first time not long ago. It was interesting how different it smells. Like a scent time machine. Wonder how leaded gas smelled lol
« Last Edit: March 29, 2020, 09:51:22 PM by Pielz »
« Reply #11 on: March 30, 2020, 04:10:48 AM »
I definitely plan to keep it as is. Once I have it running properly, I will register it as an antique, and it will be a garage queen, and only come out occasionally. If I have it ready in time, and Rolling Thunder doesn't get canceled, I plan to ride it to Washington DC to participate this year.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #12 on: March 30, 2020, 07:24:05 AM »
You have bags for it, why not a happy camper tour on that bike for old times when it runs good? ;)
Offline kap384@telus.net
« Reply #13 on: March 30, 2020, 02:31:09 PM »
Awesome bike and great story.  Thanks for posting. My '77 750F was my parent's as well!  Need to get my K0 on the road.
« Last Edit: April 13, 2020, 09:31:27 AM by kap384 »
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
« Reply #14 on: March 31, 2020, 07:06:48 AM »
Nice bike and great story.  The bike will forever be a bond between you and your father.
My father was responsible for getting my brother and myself into motorcycles, he bought us bikes when we were young.
« Reply #15 on: March 31, 2020, 09:42:38 AM »
Awesome bike and great story.  Thanks fo posting. My '77 750F was my parent's as well!  Need to get my K0 on the road.
It's nice to have something like a bike that you can use and enjoy to remind you of your parents.
The K0 450s are cool. Always one of my favorites.
I want to get an old 305 Super Hawk at some point too. Dad told me about the one he had while he was in the Navy, and I like the way they look too.
Too many projects for that right now though. I have to get my CB750K7s going first, then the Dream 305 I just bought needs to be picked up and and I have to get it fixed up and running, and possibly a CB750 chopper/rat bike with my spare '75 CB750 engine before I start to think of any more bike projects.
My dad fixed up an old PUCH moped and an old Sno-Burrow for me when I was a kid. The Sno-Burrow was great for running around on the farm. I've been hooked ever since.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #16 on: March 31, 2020, 09:45:46 AM »
I may end up riding it back to Michigan at some point, but the Goldwing is just more comfortable for long trips like that. I don't think Mom has any interest in riding on a motorcycle anymore either, but her and my sister may appreciate seeing it running and being used.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #17 on: March 31, 2020, 09:47:16 AM »
I figured I would start with the easy, and put some seafoam in the gas, even though I do not think it is a fuel problem. I let it run for a few minutes, and shut it off. After a couple of hours, I started it up again, and it is still running the same as it was. I think for my next steps, I'm going to measure resistance of the coils and spark plug wires and boots. I'll also double check and clean all electrical connections between the points and coils. Next I'll install the new condenser that Dad bought and see how it runs. Hopefully that will be all it takes, but if not, are there any suggestions on a next step? Perhaps a new spark plug, or synching the carbs? I don't have gauges to do a carb synch, but I guess I need to get some at some point, with all the old Hondas I have.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #18 on: April 01, 2020, 09:02:32 AM »
Today I cleaned all electrical connections between the points and coils, and put them back together with a little silicone grease. I installed the new condenser, measured the resistance of the coils and spark plug boots. One of the boots is completely open, infinite resistance. I just got on ebay and ordered a set of NOS boots. I also ordered some new plugs, and a turn signal relay. Once I get those in, I'll try to start it again.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Pielz
« Reply #19 on: April 01, 2020, 01:19:09 PM »
Nice!
« Reply #20 on: April 11, 2020, 05:39:33 PM »
The NOS spark plug boots came in and I installed them, but the little wires inside the boot that hold it to the top of the spark plug were thinner than the originals, and did not grip the spark plug very well. And the new spark plugs did not have the 2 piece screw off top, so I struck out on both of those. Back to the internet to try again. I found that B8ES plugs are "discontinued and replaced by BR8ES", so I ordered 4 of those. I also ordered 2 NGK 8032 spark plug boots. In the mean time I tested the condensers (both old and new) with my capacitor tester (yes, I am an electronics nerd) and they all test fine. I installed the new plugs and boots tonight and started up Dads bike again. It is running on both cylinders, but took off to about 5,000 RPM. I shut it down, and am moving on to the carbs. I don't know much about carbs, I have only really cleaned them, and never had to adjust any. I have the FSM, and a copy of the Honda Carburetor Manual so I guess its time to start learning.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #21 on: April 11, 2020, 06:32:49 PM »
Visual inspection solved part of that problem. When I put the tank back on I caused a bend in the throttle cable to the right carb, so with the left carb in idle position, the right was in a partly open position. With that corrected, I started it up again, and idle is between 2,000 and 2,500 RPM. But the right pipe is much cooler than the left again. It seems like I have fuel, air, and spark to the right side if that carb being open is causing the engine to run faster, and the left side as well since that pipe is heating up much more than the right. All of this leads me back to the carbs. I need to get some starting fluid to spray around the carb mount rubbers. I used to have some since I needed it to start the '84 Honda Civic I drove for a while, but can't find any in the garage. I got that car for free and that is about all it was worth, but it got me by for a while. If that doesn't effect anything, then I guess I'll have to start trying to adjust carb settings.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #22 on: April 17, 2020, 06:00:54 AM »
Well, I got a day off work, so time to work on motorcycles again. Took care of a couple other things on 2 of the other bikes, and started Dad's bike up again.
That took longer than it should have because the battery was low. It has been on a automatic float charger, so I was puzzled by that. I used a connector that was previously connected to another bike's battery when I installed this battery, and didn't check the fuse holder. Now that the blown fuse is replaced, the charger is doing what it is supposed to.
With the bike running, I sprayed starting fluid all around both carbs, and their rubber mount boots on the intake. No change in RPM at all and idle is still around 2,000 RPM, with the right pipe running cooler than the left.
Since I have very little experience with carbs, can anyone point me in the right direction?
Should I start with the pilot jet on the right carb, double checking that it is clear and clean?
Or start by adjusting the idle speed?
Or some other adjustment?
Thanks!
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #23 on: April 22, 2020, 06:11:09 AM »
I read through the Honda Motorcycle Carb manual, the carb section of the FSM, and some forum posts on the honda twins forum, along with some input from another member over there. I ran through some carb setup procedures, and still didn't have it running at idle on both cylinders. With what I had learned from my reading, plus what I was observing, I decided to pull the slow jet and clean it on the right cylinder. I didn't see anything noticeable, but ran a guitar string through it followed by a spray of carb cleaner. With the slow jet re-installed it is now running on both cylinders. Next step for me is fine tune timing dynamically, put new tires on it, then insurance and registration.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #24 on: April 22, 2020, 09:17:04 AM »
Good to hear!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1978 Honda XL100
1983 Honda CX650T
1995 Honda VFR750
2015 KTM 200 XC-W
1963 Suzuki T10
