Author Topic: Oh dear ...  (Read 46250 times)
Offline 69cb750
Re: Oh dear ...
« Reply #400 on: September 21, 2024, 10:25:11 AM »
Nippon Denso points plate
These plates were made after production ended
Plate and points have ND
Offline 69cb750
Re: Oh dear ...
« Reply #401 on: September 21, 2024, 10:31:27 AM »
Futaba points plate
Toyo and Hitachi supplied original points plates, Futaba was an aftermarket supplier of points plates, made in Japan
Plate stamped "few"
Re: Oh dear ...
« Reply #402 on: September 23, 2024, 07:45:06 AM »
Toyo points plate
Most CB750's came with Toyo points plate (a few came with Hitachi)
Plate stamped Tec
Top slot longer then bottom slots
Good info, seems a lot of discussion lately about aftermarket points/condensers.  I have a couple of plate assemblies on the shelf I need to I.D.
This info should be made into it's own thread and kept as a "Sticky".  Would you mind starting a new thread with all that info? Or, I could...    Thanks
Offline 69cb750
Re: Oh dear ...
« Reply #403 on: September 25, 2024, 04:34:37 AM »
Reaming rocker arm shaft holes.
The head sat on a workbench in a Nebraska barn for 62 years, there was oxidation.
Offline 69cb750
Re: Oh dear ...
« Reply #404 on: October 02, 2024, 05:07:24 AM »
Rocker arms
Re: Oh dear ...
« Reply #405 on: October 02, 2024, 09:12:49 AM »
Yes.
You're doing nice restoration on this square four.
« Last Edit: October 09, 2024, 07:11:06 PM by grcamna2 »
Offline 69cb750
Re: Oh dear ...
« Reply #406 on: October 09, 2024, 04:54:44 AM »
I found this rotor on usa ebay.
Rotor and box are old, perhaps 1950's
Offline 69cb750
Re: Oh dear ...
« Reply #407 on: October 15, 2024, 08:14:19 AM »
CB750 exhaust baffles
Offline 69cb750
Re: Oh dear ...
« Reply #408 on: October 15, 2024, 08:15:10 AM »
Re: Oh dear ...
« Reply #409 on: October 15, 2024, 10:48:54 AM »
New mufflers on your Ariel ??
Offline 69cb750
Re: Oh dear ...
« Reply #410 on: October 15, 2024, 11:09:01 AM »
The seller installed new mufflers, I imagine original mufflers were in sad shape.
During installation I noticed these are "fake mufflers", nothing inside.
I measured muffler id, baffle od, this might work and it did.
Re: Oh dear ...
« Reply #411 on: October 15, 2024, 12:52:08 PM »
Slick installation! I’m sure there is at least one Honda cb750 part on every “other” motorcycle I have ever owned. The Benelli had a lot….. Note the turn signals and stems. I eventually found a set of Moto Guzzi lights that matched the originals, but the stems stayed on the bike.
Re: Oh dear ...
« Reply #412 on: October 15, 2024, 12:55:40 PM »
I see  :)
Offline Kelly E
  • Geriatric Hooligan
Re: Oh dear ...
« Reply #413 on: October 15, 2024, 01:27:22 PM »
I put a Honda bolt somewhere on every non Honda bike we've resurrected except for the 64' Norton 750 Atlas. I even put one on the 90' Moto Guzzi 1000 Le Mans. We had to completely remove the stock linked brake system so it's already altered. Every time we asked the Guzzi expert about fixing the brakes his answer was "delink it" so we did.
I have a container full of Honda bolts after replacing bolts with stainless bolts and parting a few bikes so I can usually find one that will work somewhere.  I guess I'm just a rebel. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline 69cb750
Re: Oh dear ...
« Reply #414 on: October 16, 2024, 04:18:20 AM »
Did brake lever control front and rear brakes ?
Re: Oh dear ...
« Reply #415 on: October 16, 2024, 07:02:13 AM »
On the Honda Varadero both the rear pedal and the front lever operate both ends! It gets criticized when in loose sand, but works so well everywhere else I just left it alone. Combined with excellent ABS, it stops the bike in astoundingly short distances…..the brake bleeding sequence is complicated (there are about six different places to bleed it)!
Offline Kelly E
Re: Oh dear ...
« Reply #416 on: October 16, 2024, 01:10:31 PM »
The front brake lever worked one front caliper. The rear pedal worked the other front caliper and the rear caliper. There's a proportion valve that controls the front/rear bias. The proportion valve tends to corrode inside and will reduce fluid pressure down to almost nothing.
When I tested it I coasted down towards the shop from the house. I was standing on the rear brake pedal and it didn't slow down at all. The proportion valve was plugged with corrosion.
We junked the proportion valve and had to replace the front master cylinder with a different bore size for dual calipers and the rear master cylinder with a bore for a single caliper. Then we got all new lines because the lengths had changed and rebuilt all three calipers.
A bike with Brembo brakes should stop good and now it does. 8)
1983 Honda CB 1100F
Offline 69cb750
Re: Oh dear ...
« Reply #417 on: October 20, 2024, 06:30:54 AM »
I go back to the way it was which is easy to do.
I see a Nebraska farmer riding his four cylinder motorcycle down narrow roads with tall corn fields on both sides.
I see the bike parked at the farmers house.
Bike is together, thanks for coming along on my adventure, I will report what the bike is like to ride in the spring.
Re: Oh dear ...
« Reply #418 on: October 20, 2024, 10:04:12 AM »
How long was Dalio's in business ?
Offline 69cb750
Re: Oh dear ...
« Reply #419 on: October 20, 2024, 10:11:28 AM »
My guess is they sold British bikes in the 50's 60's early 70's and closed between 75 and 80 when Japanese bikes became popular.
Offline 69cb750
Re: Oh dear ...
« Reply #420 on: November 22, 2024, 07:43:55 AM »
Can anyone fix this?
Offline 69cb750
Re: Oh dear ...
« Reply #421 on: November 22, 2024, 07:44:30 AM »
Offline 69cb750
Re: Oh dear ...
« Reply #422 on: January 05, 2025, 07:17:26 AM »
I'm going back to the way it was ...
- January book review -
A chap in the UK has collected personal motorcycle stories and photos from the 60's and 70's from around the world, civilized and third and created a book "The lost biker stories".
I have a lot of nice motorcycle books but nothing like this.
Many of the stores are wild -
"We all slept on the floor of the barn, our bikes parked outside, bonfires in the field."
"Sitting around singing, drinking, hanging out"
"We would hang onto a long rope as a tractor dragged us around the field".
Stories of rain, snow, cold weather.
I once slept in the garage of a police station in Canada.
Many years later I rode my CB750 from Michigan to Seattle on US2 with friends.
We stayed at Glacier national park one night, it was 70 when we set up our tent.
Next morning I looked out of the tent, that looks like snow, it was, 6" in August.
Around noon the snow started to melt, left at 3pm and 40 degrees.
Escaped the park, 65 degrees on the other side, warm and sunny, had a nice take out dinner sitting on a park bench.
https://www.thelibertatia.com/pages/the-lost-biker-stories
Online Don R
Re: Oh dear ...
« Reply #423 on: January 05, 2025, 10:30:39 AM »
 That book looks like a good read, most of us have a lost biker story worth telling.
Re: Oh dear ...
« Reply #424 on: January 05, 2025, 05:47:16 PM »
That book looks like a good read!
