Author Topic: Where to tap a vacuum line?  (Read 926 times)
Offline Dolomite
  • I'm 40% Dolomite.
« on: March 15, 2020, 06:18:56 PM »
I need to add a vacuum line for the crankcase since I am running stacks. Does anyone know a good unobtrusive place to tap into for a vacuum line? Only idea I have so far is to tap small barb nipples into the stacks to run a vacuum from.
Re: Where to tap a vacuum line?
« Reply #1 on: March 16, 2020, 12:37:28 AM »
Why do you need a vacuum line?
Online pjlogue
« Reply #2 on: March 16, 2020, 01:53:16 AM »
If you try and tap the intake vacuum you will alter your carb mixture if you are allowing ANY volume of air to bypass the carb throat where the gas/air mixing takes place.  These engines are not designed for a PCV system.
-P.
Offline Bodi
« Reply #3 on: March 16, 2020, 04:29:37 AM »
Odd request. What is the vacuum for?
Anyway: you need a port between the throttle plate and the intake valve. There won't be vacuum in the stacks... at least not enough to do anything with, and useless for carb balancing.
You can connect a vacuum servo of some sort like an automatic petcock, or a gauge/sensor, with no issues. Just don't allow much constant flow.
Offline robvangulik
  • Honda Fourever
« Reply #4 on: March 16, 2020, 06:46:28 AM »
I suspect you  mean a crankcase breather hose...?
« Reply #5 on: March 16, 2020, 07:02:14 AM »
Which is why my original question to the poster rtill stands, without a reaso we are all peeing into the wind!!!!
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #6 on: March 16, 2020, 07:04:03 AM »
Yes for the crankcase breather. Currently its venting to atmosphere through a filter but I suspect I am still getting some blow by. I wanted to try to add a universal pcv or small catch can but I would need to plumb a vacuum line from somewhere.
« Reply #7 on: March 16, 2020, 07:18:43 AM »
Dont do it, the original 750's vented to atmosphere and the complication you will add would make tuning and running an absolute nightmare
« Reply #8 on: March 16, 2020, 08:14:36 AM »
 Us drag racers use an angle cut nipple in the exhaust to make some vacuum, if you have a 4-1, that might be useful if you can get behind the baffle where there's not much backpressure.
Offline Bodi
« Reply #9 on: March 16, 2020, 08:58:26 AM »
You can vent it in a stack but you'll just gum up that carb with oily goo. There are little "pod" filters for the vent line that collect the oil vapor and just need a solvent wash every few thousand miles, or just route it down to end behind the engine somewhere. Barring some catastrophe it won't put out enough oil to cause traction problems for the rear tire, just the 'smoke" and a drip every now and then.
