Author Topic: Tips for tightening cam sprocket bolts? CB750  (Read 597 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: March 18, 2020, 08:26:28 PM »
How do you keep the cam from rotating?
Re: Tips for tightening cam sprocket bolts? CB750
« Reply #1 on: March 18, 2020, 08:53:58 PM »
My one tip would be to not forget to use some loctite on the two bolts. I've done those on different engines but can't remember any issues with tightening,maybe snick it into low gear.
Offline disco
« Reply #2 on: March 19, 2020, 03:24:54 AM »
After that my no1 tip would be “make sure to stuff a rag into the cam chain tunnel while doing any work there”. So easy to lose those little bolts!
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline DaveBarbier
« Reply #3 on: March 19, 2020, 04:48:09 AM »
Put it in gear and step on the brake or block up the rear sprocket with wood.
« Reply #5 on: March 19, 2020, 07:02:53 AM »
  Dropping a bolt down the cam tunnel can make for a very bad day ! Yes the block of wood on the chain sprocket in gear will do the trick.
