Author Topic: Rear shock bottom bushings  (Read 842 times)
Offline Jonm99
« on: March 20, 2020, 05:44:12 AM »
Hi guys
Hope everyone is in good health and weathering out the Corona craze.
Before installing new rearshock bushings (the ones in the rear of the swingarm, I wanted to be sure that I have the orientation right (can't really tell from the parts fisch). Can anyone tell me which side faces inwards (see attached), or does it not even matter?
Thanks!
Jonathan
1977 cb750k with original airbox, PD41a carbs, slow jets=35, main jets=120, Delkevic 4in1 headers, 18" Cone engineering QC muffler, 7" headlight, dynatek ignition, ss r/r, clip ons, and ebc front brake rotor. All the rest stock, for now. First restoration, lots to learn!
Online dave500
Re: Rear shock bottom bushings
« Reply #1 on: March 20, 2020, 05:52:43 AM »
dont matter,ive only done one set,they seem to last forever?
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: March 20, 2020, 06:00:33 AM »
+1 to first answer. Clean the tube and warm it with a heat gun. Freeze the busing and use lubrication, for easier install.
Offline Jonm99
« Reply #3 on: March 20, 2020, 06:39:23 AM »
Got it, thanks guys :-)
Online dave500
« Reply #4 on: March 20, 2020, 02:05:30 PM »
use a socket with nut and bolt,itll press in fine that way.
« Reply #5 on: March 21, 2020, 11:28:46 AM »
I read somewhere that the hole in swingarm is slightly conical so bushing will slip easier in from inside?
It was Hondaman and CB750  bushings.
Offline Jonm99
« Reply #6 on: March 21, 2020, 11:52:11 PM »
I got them in, was pretty easy actually. However, the bushings on the front side of the swingarm is a whole other story. The all thread snapped when the bushings were midway in and by the time I got my hands on another one, the bushings warmed up and the swingarm cooled down. The second all thread snapped too (I was really putting a lot of weight into getting over the friction). So bottom line is this, I have one bushing which is 2/3 in and another about 1/2 in. I don't really see any advantage to freezing / heating up at this point so where does that leave me? I could try again with a wider diameter all thread, unless you guys have a better idea?
« Reply #7 on: March 22, 2020, 12:50:16 AM »
In USA?
If yes, send it to Hondaman.
Offline Jonm99
« Reply #8 on: March 22, 2020, 01:11:59 AM »
Unfortunately not, would love to have had his help on this (and a bunch of other hair pulling tasks with this rebuild).
« Reply #9 on: March 22, 2020, 04:10:55 AM »
Photos of the situation will make others to chime in and guide you to success!
« Last Edit: March 22, 2020, 05:57:48 AM by PeWe »
« Reply #10 on: March 22, 2020, 06:02:34 AM »
If they are half way in the only answer is a hydraulic press at a machine shop
Offline Jonm99
« Reply #11 on: March 22, 2020, 10:32:12 AM »
And some pics of my mess.... What are the chances that a larger diameter all thread will do the trick?
« Reply #12 on: March 22, 2020, 10:45:11 AM »
Long thick fine threaded bolt with washers will not force it together when tighten it?
A press might be the way. Usually doing one by one I guess.
Offline Jonm99
« Reply #13 on: March 27, 2020, 05:23:41 AM »
That worked - so more thread (larger diameter), more grease (on the remainder of the exposed bushings and on the thread itself), and more perserverance. Good to go now!
Thanks guys :)
« Reply #14 on: March 27, 2020, 10:25:30 AM »
Perfect, just in time for Friday GT. (Gin Tonic)
