« Reply #2 on: March 20, 2020, 12:48:19 PM »
The carbs have a number stamped into the bracket that holds them together, usually on the right (throttle) side. It maight also be on the carb body on teh #4 carb (again the right most carb).
Once you know that you can get the proper gasket set. Generally speaking if you have the factory needles and jets I would not replace them with any that might come with the carb kits as the aftermarket jets/needles often aren't the size and taper that they say they are.
Also, you should just post questions like these to the regular SOHC4 bikes board. The Open Topic board is generally for non-motorcycle related stuff and you will get more responses from the proper board. You don't need to start a new thread there for this, one of the moderators will move it for you soon.
« Last Edit: March 20, 2020, 12:50:08 PM by Bankerdanny »
Logged
Current: '76 CB750F. Previous: '75 CB550F, 2007 Yamaha Vino 125 Scooter, '75 Harley FXE Superglide, '77 GL1000, '77 CB550k, '68 Suzuki K10 80, '68 Yamaha YR2, '69 BMW R69S, '71 Honda SL175, '02 Royal Enfield Bullet 500, '89 Yamaha FJ1200
