Author Topic: Bar Inner Diameter  (Read 1742 times)
DF
Bar Inner Diameter
« on: February 08, 2007, 05:00:44 PM »
Hey - can anyone tell me off the top of their head what the inner diameter of my 1974 CB550 handle bars would be?
I am looking at some bar-end mirrors from http://www.trak-tek.com/products/front/barEndMirrors.html
They are available in 12mm to 22mm.
Pretty expensive, but I can't seem to find anything else I like.
Thanks!
Shadowjack1020
Re: Bar Inner Diameter
« Reply #1 on: February 09, 2007, 02:59:11 PM »
You probably know this, but bike bars are almost universally 7/8" OD. Harleys and cruiser-style bikes are 1", but there are ALWAYS exceptions. Having just measured the ID of a set of 7/8" CB750 bars, it's 21 mm inside.
DF
« Reply #2 on: February 10, 2007, 08:58:29 AM »
Right on - Thanks.
Offline gerhed
« Reply #3 on: February 10, 2007, 09:06:33 AM »
Depending on the pull back angle and length of your bars,
bar end mirrors might not work too good.
Difficult to get decent rear line of sight.
          83 XL600R in CB360 Frame
Peter
« Reply #4 on: February 10, 2007, 01:21:30 PM »
According to my caliper, 11/16"
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #5 on: February 10, 2007, 04:52:47 PM »
Round ones are hard to find. I found a similar set to those in the link, too small and way more $$$. The other factor is they are the first thing to hit the ground if the bike gets knocked over. I have literally replaced dozens.
Most catalogues have bar-ends for about $20-$30 but they are somewhat rectangular and not real stylish.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Cattledog
« Reply #6 on: February 28, 2007, 10:24:16 AM »
did you order from Trak-Tek?
If yes, did the mirrors arrive yet?
Offline SD750F
    • My Business Site
« Reply #7 on: February 28, 2007, 12:12:33 PM »
Just thought you should know, 11/16" = 17.5mm...
MODIFIED NUMBERS... CALCULATOR ERROR ;)
And a ID of 21mm = .826" or a wall thickness of only .024"!!!  So I think it would be safe to say there is some variance from one 7/8 standard handle bar to another as well as factoring in manufacturing technique and whether or not the tube was "pulled and formed" near the bar ends...
Something to consider.
Scott
« Last Edit: February 28, 2007, 02:30:04 PM by SD750F »
Cattledog
« Reply #8 on: February 28, 2007, 01:23:19 PM »
just check my id and it is 0.706 or 18mm.....
