Author Topic: 750k Frame Paint?  (Read 1797 times)
Offline 750K5
  • agentsmith5
750k Frame Paint?
« on: March 26, 2020, 08:18:53 AM »
Good morning,
I'm getting ready to start prepping for painting my frame. Choosing to paint vs powder coat because the frames were originally paint. I'm curious if the original black paint was satin or gloss? What products have you had success with? Did you clearcoat?
Any advice would be appreciated.
Stay Well. Stay focused on your Hobbies!
Thanks in advance.
K5
Offline C2YT
  • Proud Hoarder
Re: 750k Frame Paint?
« Reply #1 on: March 26, 2020, 08:26:15 AM »
I want to say the original paint was more of a satin, based on my bikes. I have had good luck with VHT Fame/roll bar paint.
As a price point, I was quoted $175 to blast/coat a CB500 frame.
1971 CB500 - Sunrise Orange, CBR Front End, Project
1975 CB550 - Sunrise Orange, Clip-Ons, 4into1, Brat
1974 CB750 - Sunrise Orange, 4into2, 16" Rear, Cruiser
Offline beemerbum
« Reply #2 on: March 26, 2020, 08:50:34 AM »
Good morning,
Thanks in advance.  I and many others have found RustOleum appliance epoxy to be satisfactory in terms of gloss and original appearance for the frame
K5
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: March 26, 2020, 09:19:05 AM »
I would say the original finish is more of a semi-gloss.
Paint vs powder coating is a potato-potahto thing. They both have strengths and weaknesses and neither is materially superior.
I like paint because it can easily be repaired if damaged. I am a big fan of this one from Harbor Freight. I have used it on multiple SOHC4's and it is virtually indistinguishable from stock.
« Reply #4 on: March 26, 2020, 09:50:53 AM »
Offline jakec
« Reply #5 on: March 26, 2020, 11:09:49 AM »
forum consensus seems to be rustoleum appliance epoxy black with no primer. I have used it and it looks good. it's a very low gloss black.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline 750K5
  • agentsmith5
« Reply #6 on: March 26, 2020, 03:27:57 PM »
I was quoted here in Denver $550-600 for a 750 frame and other black parts associated.
Offline gmog44
« Reply #7 on: May 19, 2020, 09:18:50 AM »
Joining a little late...
The quote i got here in Portland is in line with 750KS’s.  i’m with C2YT on the Rustoleum without epoxy. I will not strip the frame to the metal, but prep the rust spots and factory paint before coating.
1. How robust is this finish?  (Assuming meticulous prep, of course)
2. My rims need paint: same solution?  2k clear topcoat recommended?
'78 CB550
'72 CB450
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #8 on: May 19, 2020, 09:45:01 AM »
I'm a POR 15 fan, it's very tough. Use chassis black top coat for a beautiful covering that is tough as nails.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline gmog44
« Reply #9 on: May 19, 2020, 07:59:52 PM »
MauiK3, thanks!  I can see why you’re a fan.
'78 CB550
'72 CB450
Offline disco
« Reply #10 on: May 20, 2020, 01:34:45 AM »
I’ve given 2 frames to the powder coater to have them done (semi gloss), mainly because I can’t spray 2-pack paint safely. I could have used a rattle can, but glad I didn’t. The number of times the carbs have accidentally over flowed, I would have no rattle paint left on the frame! Over flows have been very minimal, but the powder coat stands up to fuel spills much better than normal paint.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
« Reply #11 on: May 20, 2020, 06:49:26 AM »
First off, semi gloss black.  I prefer powder coat, my powder guy charges $100 to blast and coat - a no brainer for me.  I have 3 bikes with powdercoat, never have had to touch up from damage.
Current K6 project:
Offline gmog44
« Reply #12 on: May 20, 2020, 08:29:05 AM »
Disco/Stev-0, i appreciate the input. With quotes in the $500 range, it coating hammers my budget. Where is your guy?
'78 CB550
'72 CB450
« Reply #13 on: May 20, 2020, 09:32:32 AM »
Where is your guy?
In Austin, close to the Circuit of the America's F1 race track.
Offline grcamna2
« Reply #14 on: May 20, 2020, 09:54:15 AM »
Where is your guy?
Steve, Did they also do your Kawasaki triple ?
« Reply #15 on: May 20, 2020, 01:33:36 PM »
Where is your guy?
No, my H2 came to me as a basket case and the frame had already been powdered and was in perfect condition.
However, now that my K6 project is about done, I have decided that an H1 500 project is next and will be taking the that frame to him for semi gloss black powder.
Offline gmog44
« Reply #16 on: May 20, 2020, 01:54:43 PM »
Thanks for all the input, ill let you know how it turns out.
'78 CB550
'72 CB450
Offline grcamna2
« Reply #17 on: May 20, 2020, 02:13:54 PM »
Where is your guy?
Steve, Your H2 is a 73? I wondered does it have as much 'kick' as the early H2's ?
Offline Alan F.
« Reply #18 on: May 20, 2020, 02:47:42 PM »
Did my K8 today with Appliance Epoxy.
Offline Swoop
« Reply #19 on: May 21, 2020, 05:14:00 AM »
Hi, Mind if I ask which paint you used.....I see an appliance epoxy in black stainless steel, a black Gloss and a black mentioned on the internet. Would you have a product code? Did you spray or brush?
Thanks
Steve
Offline Alan F.
« Reply #20 on: May 21, 2020, 06:42:07 AM »
Rustoleum brand, bought this can at Walmart but it's fairly common. About $6
Offline Swoop
« Reply #21 on: May 21, 2020, 08:29:01 AM »
Thanks
Offline Alan F.
« Reply #22 on: May 21, 2020, 08:42:08 AM »
I didn't realize who I was talking with. How's things Swoop?
Last time we talked Frame Paint wasn't on your mind for your Seeley framed 750.  8)
Offline grcamna2
« Reply #23 on: May 21, 2020, 08:43:02 AM »
I used this same paint before on a bike I bought,I had the frame blasted(surface rust)first and it worked well.When it cured,it turned darker  ;) and was good quality,even though they don't recommend it for outdoor applications..
