Author Topic: Upside down valve guides?  (Read 1809 times)
Offline bomorr
    • sohc/4
« on: March 26, 2020, 02:04:46 PM »
So I picked up this 72' motor a few years ago and since we all have so much time on our hands lately I decided to dig into it to see what I needed to replace. When I got to taking the valve springs off I got a surprise that looks like someone at some point has done a top end rebuild on this and flipped all the exhaust valve guides upside down and no there were no seals over the guides ok the exhaust side. First time I have seen this and I wanted to make sure that this wasn't something that was normal. Guides aren't too worn so I don't want to pull them if it's not going to change the overall performance since I am just doing a quicker resto-mod with mostly original parts.
Sent from my Pixel 4 XL using Tapatalk
Re: Upside down valve guides?
« Reply #1 on: March 26, 2020, 02:07:52 PM »
The first few years did not have seals.
Offline bomorr
    • sohc/4
« Reply #2 on: March 26, 2020, 02:10:41 PM »
Interesting, so on this head the intake side has them but not the exhaust.
« Reply #3 on: March 26, 2020, 02:47:47 PM »
Correct, what do the oil restrictor jets look like?
Offline bomorr
    • sohc/4
« Reply #4 on: March 26, 2020, 02:56:49 PM »
Haven't attempted to get them out since they won't come out with a magnet tool. I may just use a wire to clean them out and leave them as is
« Reply #5 on: March 26, 2020, 03:16:08 PM »
 I would replace those exhaust guides with guides that take oil seals. I'd also recommend using iron guides. You'll need a valve job after replacement. The oil control jet is pressed in though the occasionally can be removed......just leave them in.
Offline bomorr
    • sohc/4
« Reply #6 on: March 26, 2020, 08:12:13 PM »
Yea I'm probably going to send the head over to cyclex for the whole head job.
Online scottly
« Reply #7 on: March 26, 2020, 08:32:44 PM »
Just run them as is. The knife edge on the end of the guides acts as a scraper to remove some of the oil from the valve stem, in lieu of a seal. My K1 motor doesn't have seals on the exhaust side either, and sometimes it puffs some oil smoke out of the exhaust, but it's been that way for 40 years now. ;)
« Reply #8 on: March 26, 2020, 11:54:09 PM »
Those look like the "pepper pot" restrictors so definately early head. Yamiya list the expensive restrictors
« Reply #9 on: March 28, 2020, 01:00:46 AM »
No problem to take out those oil restrictors (orifices).
I had to do that, a friend told me how to which I did. Easy!
Find my post with photos.
 I sanded my restrictors when out just a little with 400 grit paper to let them go in easier next time.
http://forums.sohc4.net/index.php?topic=175940.msg2051709.msg#2051709
I also had an early head with ex guides without seals. Smoked.
Replaced them.
Maybe the valves are bad too. Mike (MRieck) has the parts, tools and skills to do it right.
« Last Edit: March 28, 2020, 01:06:59 AM by PeWe »
Offline Kevnz
« Reply #10 on: March 28, 2020, 01:12:47 AM »
Hi Team,
I'm not sure about SOHC4 motors specifically, but in general, engines don't need oil seals on the exhaust side as there is no suction on that side of the motor, only the inlet side as the fuel \air mixture is drawn in by the induction stroke.  I've never seen oil seals on the few sohc 4 motors I've had apart.
Kevin
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
« Reply #11 on: March 28, 2020, 01:33:57 AM »
Oil will splash, follow the stem and smoke. No one liked to ride behind my bike in 120-160kmh.
I thought it should smoke just a little when starting it.
I did not realize how much until I tested. The recommendation on this forum was to replace the guides.
I replaced the entire head to a later K6 with new ex guides and valves. All In were good. My K2-75 needed a later head anyway.
No more smoke when riding.
That old K1 head will get new guides and all valves.
« Last Edit: March 28, 2020, 01:46:35 AM by PeWe »
« Reply #12 on: March 28, 2020, 02:19:39 AM »
Try explaining why the F2 can drop to 150 miles per pint with clouds of blue smoke when the guides wear and seals go
« Reply #13 on: March 28, 2020, 01:46:42 PM »
Those are the BEST valve guides Honda ever used in these engines. They are made from Stellite, hard as diamonds, and are found in K0/K1 "old factory" heads only. They do not have seals (nor do they need them) and if they still have good clearance (less than 0.0032" valve 'wiggle' when the valve is lifted 3mm off the valve seat, measured at the edge of the valve) I recommend using those guides. They went 138,000 miles on my K2 and were barely worn out at that point.
Offline Henning
« Reply #14 on: March 28, 2020, 01:49:17 PM »
This has been up a few times so let me add my two cents. The early bikes without exhaust valve seals "can" smoke but not necessary "will" smoke. My K1 with 55K miles doesn't smoke at all, and neither did the K1 I owned back in the day. That said, if you're replacing the guides, seals are the way to go.
71 or thereabouts 750 K1 - this one should have been put down
« Reply #15 on: March 28, 2020, 03:31:58 PM »
because the intake guides are just as worn out as the exhaust, seals and all.  The guides wear out due to bad valve train geometry inherent with the f2's bigger intakes.
Offline bomorr
    • sohc/4
« Reply #16 on: March 28, 2020, 03:59:58 PM »
Yea, I'll be checking the tolerances this weekend. I figure if they check out I'll just replace the seals on the intake side and call it a day. All the springs, pistons and cylinders check out I just have to measure the cam and valves next.
« Reply #17 on: March 28, 2020, 05:52:09 PM »
Nope, i stripped and rebuilt that motor, inlets were perfect only think worn was exhaust guides. New guides and seals with all gaskets and back to being like new
« Reply #18 on: March 28, 2020, 07:37:47 PM »
If the intake guides have not been changed, then they will also be Stellite.
It took me 4 years to locate a new set of those prior to my 2013 rebuild, and when I took it to the machine shop my 'regular' guy was on vacation. The 'stand in' machinist there did not know me, and he reamed the guides to [his] specs after I told them  0.2600" hole size, no more than 0.0012" intake clearance. He ruined them, making them like a car's head (0.0025" clearance, 0.2625" hole size). I can't say on the Internet the words that come to mind, even now....so I had to go to bronze guides instead (and re-replace them all). While bronze guides are a close second in performance, the Stellite guides of the early engines were unsurpassed for friction reduction and longevity. Honda changed them to cast iron after the mid-year (3/1972 production) K2.
Offline bomorr
    • sohc/4
« Reply #19 on: March 28, 2020, 07:59:58 PM »
Ouch, that hurts to read
« Reply #20 on: March 28, 2020, 11:04:26 PM »
I have new Honda stock steel guides for seals to be used in my smoking  K1 head with no oil seals on ex
That type has holded up well in my K6 head.
« Reply #21 on: March 29, 2020, 07:01:42 PM »
I ordered a new set of Honda's current version of these guides a few years back, and they are a low-density, somewhat porous iron material. It isn't as durable as the older cast irons, from what I can tell, but maybe the porous nature will help it lube better? Dunno, haven't installed them to find out. I've switched to bronze instead.
« Reply #22 on: March 30, 2020, 07:21:32 AM »
Have Honda changed the material for the K2- K6 guides since the mid 80's?
Offline bomorr
    • sohc/4
« Reply #23 on: April 03, 2020, 06:33:27 PM »
@HondaMan can I get the same outcome of measuring wiggle if I measure the bore of the guides and the stem size and subtracting the two? Currently waiting on shipping for a proper dial gauge to get into the head to measure wiggle.
Here is what I measured:
Bore size on EX: 0.2600
Bore size on INT: 0.2602
Stem size on EX valve: 0.2580
Stem size on INT valve: 0.2590
Taking those along with the 0.0032 wiggle spec. I should be OK right?
I obviously will be doing the wiggle test when I get in the dial gauge but I couldn't wait another few days to keep digging into the head.
Couldn't find an official spec on the stem size of the valves
« Reply #24 on: April 03, 2020, 08:26:40 PM »
Yep. Somewhere around 1998-2002, from what I can tell.
« Reply #25 on: April 03, 2020, 08:35:34 PM »
It's real hard to measure them that way because of the wear angle. Imagine, for example, if you sawed a head in half thru the guides (which I might do to one I have here that is otherwise not usable), you would see that the wear is on the outside of the guides at their tops and the inside (toward chamber center) at the bottom. This is due to the angle of the rockers and how they slide back-and-forth across the tips of the valves during an opening-closing cycle: it loads the outside as the valve begins to open, then the washed-off (by gasoline) valve stem in the intake passage grinds its way closed against the center-of-head side of the guide at the bottom. So, the wear is measured in that axis, which tries to take into account the wear at the top AND bottom of the guide. With new clearance of 0.0012" stem-to-guide, this comes out to 0.0024" of 'wiggle' from center-of-head toward intake port, measured with a dial gage. Honda spec'd 0.0032" as worn-out, but I have found they run fine until 0.0045" or so if the valve seals are still soft and pliable. On the exhaust side the stock clearance is 0.0020", so the wiggle starts at 0.0040" there, and by about 0.0070" or so they start to leak oil and make messy exhaust ports, even with new seals.
So, it's really hard to try to measure them any other way.  :-\
Online scottly
« Reply #26 on: April 03, 2020, 10:05:20 PM »
This is why the early exhaust guides with no seals last longer; they have more lubrication than those with seals.
« Reply #27 on: April 03, 2020, 11:12:31 PM »
Then it comes to the oil. :D
.... as I read on a Porsche forum where an experinced race mechanic shop owner (about track days std cars) mentioned the importance using correct oil with correct viscosity keeping the oil pressure up when hot,  lubricating the valves/guides with splashes only ...
and how relatively quick the oil degrades its viscosity after a few hundreds miles only.
I got the thought about Hondas very short oil change intervals then.
The oil in a CB is really abused by clutch and gearbox which the oil in a car never will.
