Author Topic: Almost too embarrassed to ask - part dropped in crankcase CB750 - Got it out!  (Read 1412 times)
Offline markb
  • When I finish my current project I might be a
I can't believe how stupid this is. :-[ I was assembling the cam chain tensioner assembly and somehow one of the rubbers on the cam chain tensioner roller pin fell into the crankcase. And I was being so careful. >:( I looked in from the top and since the oil pan isn't on yet I looked in from the bottom too. I even looked on the bench and around on the floor to make sure it somehow didn't drop into the case. I'm thinking of getting a fiber optic scope so I can try to get a better look. This must have happened to someone else before so I'm looking for ideas. Anything so that I wouldn't have to split the cases.  ::)
« Last Edit: April 02, 2020, 05:33:47 AM by markb »
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Re: Almost too embarrassed to ask - part dropped in crankcase CB750
« Reply #1 on: March 30, 2020, 07:52:51 AM »
Stuff happens so don't be embarrassed. Maybe some compressed air shot shot down the cam tunnel will get it moving downward if you cannot get eyes on it.
Offline 69cb750
« Reply #2 on: March 30, 2020, 07:55:19 AM »
The rubber pieces that press into the cam idler pin ? (these are pretty big)
Remove idler and look inside with flashlight.
Not found, flip engine over keep level with block, remove oil pan and look.
Offline markb
« Reply #3 on: March 30, 2020, 09:06:05 AM »
The idler isn't in. The rubber dropped while I was installing it. Oil pan isn't on yet. I looked but couldn't see it.
I like that idea.  :)
    • http://forums.sohc4.net/index.php?PHPSESSID=6apu55ft0mo8v8kda4iemuu7j1&/topic,60973.0.html
« Reply #4 on: March 30, 2020, 02:47:19 PM »
this vay....
Offline Register
« Reply #5 on: March 30, 2020, 11:16:48 PM »
you need to have a word with that delivery guy
Offline Flyin900
« Reply #6 on: March 31, 2020, 01:44:50 PM »
That’s one way to get oil to the top end after a long layup. :)
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline markb
« Reply #7 on: April 01, 2020, 07:22:15 AM »
It worked! ;D I fired up the compressor last night and 15 minutes later it was out. I blew from the top and then the bottom and then tilted the case around and blew from the top again and it came out. What a relief. That will never happen again.  ;)
« Reply #8 on: April 01, 2020, 09:02:26 PM »
  Glad its out and you can continue on. Whats the engine number that your working on now Mark ?  Eric
Offline markb
Working on three engines at the same time, 748, 1490 and 1769. It's nice to get everything set up and do all three. Should save time overall. By the end of this coming weekend I hope to have the cylinders and heads on all of them.
  Sounds like a good plan,sort of like an assembly line and triple the pleasure when you get to the last station !!
Offline markb
Here's a link to the "assembly line".  ;)
http://forums.sohc4.net/index.php/topic,181797.msg2105658.html#msg2105658
I wouldn't have been close to this far without the easy removal of that dropped part.  ::)
« Last Edit: April 09, 2020, 10:20:05 AM by markb »
