Author Topic: Use washers when replacing motor screws with stainless?  (Read 352 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: March 30, 2020, 09:08:25 AM »
I had to replace the leaking pucks in my CB750, and want to replace the top-end screws with stainless Allen. Do you use washers under the bolt heads?
Online Jerry Rxman Griffin aka MuthaF'er
Re: Use washers when replacing motor screws with stainless?
« Reply #1 on: March 30, 2020, 09:11:58 AM »
I haven't on either bike
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: March 30, 2020, 09:16:13 AM »
Thanks Jerry. Just a dab of anti-seize?
« Reply #3 on: March 30, 2020, 01:06:56 PM »
The instructions that come with the screws I bought say to use the correct anti-seize paste.
Offline jakec
« Reply #4 on: March 30, 2020, 01:54:13 PM »
the bolt kit that I bought came with washers for all bolts because the allen head is smaller than the flanged bolts. If it's flanged I think you need a washer.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #5 on: March 30, 2020, 05:16:16 PM »
Use a little aluminum anti-seize
« Reply #6 on: March 30, 2020, 06:03:13 PM »
I use the stainless washers with those, mostly because the heads are smaller and can ding up the faces of the screw holes.
