I'm not sure why it matters. If the tires are from 1993 or before they should be replaced.
I'm considering selling the bike. It is 100% stock, and was thinking original tires would be a plus.
Am I not correct on this?
[/quote]
THe original Flintstones from the factory in 1981 would be worn or date coded out after 12 years, so likely someone switched to Dunlop tires. Honda would not have put two different models of Dunlop tires in model K627's on the front and a Dunlop F11 on the rear. Possibly the owner needed to switch to those two Dunlop combinations, as the only combination that would fit the rims. Maybe it was a thing back in 1993, as a performance handling package.
Install new tires and if the new owner wants the old tires....... then here you go sir!
