I have a 1971 CB500 and I just did a top end rebuild.
I’ve installed pistons, rings, gaskets. Adjusted valves. Lapped valves too. Followed the manual on setting the chain tensioner and camshaft positioning to TDC. (Top dead center)
I have the dyna s ignition, however I am having troubles setting my timing correctly. With the test light on the blue wire I’m seeing that my timing is on 2-3 when it should be 1-4. I switched the wires and it instantly started up but I’m not sure if that’s a good thing or not.
Why would the timing be backwards?
