Author Topic: Clutch hub nut tool for CB750  (Read 529 times)
Offline fxef79
« on: April 07, 2020, 08:05:27 AM »
Can anyone confirm... I think the large end of this tool would work for CB750 clutch hub nut? Inside diameter 24mm.
https://www.amazon.com/JINGKE-Locking-Removal-Wrench-Remover/dp/B07D49SBBD
This might not be the best quality, longest lasting tool in the world, but I'll probably use it once or twice.
Re: Clutch hub nut tool for CB750
« Reply #1 on: April 07, 2020, 08:58:02 AM »
There are several suppliers have them for 20 bux or less.
Offline fxef79
« Reply #2 on: April 07, 2020, 09:11:21 AM »
This one is $9.  Shipped.
Yes, I'm a cheap a**.  But if the tool is good enough, I don't see paying more than necessary, and $9 is well worth my time not to try to make my own.  I'll happily pay $9 to try it out.
Even if it's really poor, it's likely better than bashing on the nut with a screwdriver and hammer, and guessing whether the torque is right.
Offline Kevin D
  • SE Michigan
« Reply #3 on: April 07, 2020, 09:13:45 AM »
Here's my own clutch nut wrench. I'm measuring 24mm inside, 28mm outside, so the teeth are slimmer on my tool/fatter on the amazon tool. Is that gonna be an issue? I don't know.
I'm about to open up my clutch. I haven't used this wrench for 12? yrs and I only found it yesterday, so it was handy today.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline fxef79
« Reply #4 on: April 07, 2020, 09:24:44 AM »
FWIW this isn't even the cheapest spanner tool... mainly I'm just checking that the 24mm I.D. is correct for the CB750 clutch hub nut.  I can only get over to the workshop about once a week, and I don't want to wait that long before I go ahead and get a spanner tool on the way.
Offline fxef79
« Reply #5 on: April 07, 2020, 09:25:19 AM »
Thanx for the confirmation - 24mm ID.
Offline fxef79
« Reply #6 on: April 07, 2020, 09:31:12 AM »
Motion Pro 08-0015 is 24mm I.D. and is supposed to be correct for "pre-78 CB" models... I think that also tells me "yes".
« Reply #7 on: April 07, 2020, 09:41:47 AM »
I use this tool attached on my torque wrench
https://www.ebay.co.uk/itm/Honda-Clutch-Centre-Nut-Tool-for-CB750-SOHC-Four-K0-to-K8-HWT002/261747692417?hash=item3cf160d381:g:HfgAAOxyVaBSzt1L
I also have the tools for wheel bearing retainers from same seller
https://www.ebay.co.uk/str/Honda-Classics-Restoration-Services?_trksid=p2047675.l2563
And the CB750 shop manual in paper form despite I have a copy in my computer. releaxing to read in front of the TV with clean fingers not making it dirty, same treatment as Hondaman's book. ;)
« Last Edit: April 07, 2020, 09:45:31 AM by PeWe »
Offline fxef79
« Reply #8 on: April 07, 2020, 09:45:02 AM »
Well crap... that's 16mm?  Confidence gone.
OK... I gotta go over and measure this nut.
Offline Kevin D
  • SE Michigan
« Reply #9 on: April 07, 2020, 10:55:36 AM »
16mm
Probably the thread size
There are threads within this forum that describe a homemade clutch nut tool using a donor socket and a grinder. Just gotta find it.
« Last Edit: April 07, 2020, 11:18:11 AM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
