I've done the searches and cannot seem to find a simple, spelled out, how to test a rectifier and regulator write-up. What is the proper way to do it? The settings, orientation of the leads, etc...
I'm working on a '75 550F. OEM stator, field coil, rectifier and regulator.
I'm dealing with a charging issue that I initially believed to be my stator, so I sent it off to Rick's. They told me the stator bench tested fine and suggested I test a few other items before moving forward with a rewind. I have a Gardner Bender GDT-3190 digital multimeter. It's nothing fancy, but it has most of the basic functions. Can I accurately test the rectifier and regulator with this multimeter?
https://www.gardnerbender.com/en/p/GDT-3190/Gardner-Bender-GDT-3190-DigitalI tested the field coil. Multimeter set to 200 ohms, leads to green and white wires. It measured at 4.6 and no grounding issues.
When I tested the rectifier, I had the multimeter set to 200K ohms, black lead to the red/white wire, red lead to the yellow wires. They measured 86.3, 87.5, 87.9. When I switched the leads around, no measurement was displayed.
I then put the red lead to the green white and the black lead to the yellow wires. They measured 85.3, 83.6, 83.8. When I reversed the leads, again, no measurement displayed.
Am I doing this correctly?
For testing the regulator, I had the multimeter set to 200 ohms. With all the regulator wires disconnected, one lead on the black wire tab and the other on the white wire tab. It measured 0. I disconnected the battery negative terminal, put one lead on the black wire that goes to the regulator and the other lead to the battery ground wire. It measured .3.
Any guidance with how to properly test these items is greatly appreciated. Thank you.
