Author Topic: Battery leads CB500 Four K1  (Read 382 times)
Offline Register
« on: April 13, 2020, 01:18:37 AM »
Hi, I need to buy extended battery leads to reach the relocated battery.
I'm struggling to understand the sizing, 16mm2, 20mm2, 25mm2, 35mm2 etc.
Battery is 240 CCA.
What size should I be using?
Thanks
« Last Edit: April 14, 2020, 06:27:43 AM by Register »
Re: Battery leads CB550 Four K1
« Reply #1 on: April 13, 2020, 03:30:58 AM »
Not the battery that determins size but starter current, basically you need a bigger size than that fitted due to length
Offline Register
« Reply #2 on: April 13, 2020, 08:16:16 AM »
Thanks. So for the battery negative lead, do I need to run it to the engine of will anywhere on the frame do?
Offline Bodi
« Reply #3 on: April 13, 2020, 09:03:53 AM »
Go to an engine bolt, ring terminal contacting (scraped clean) engine case, with an engine bolt frame to engine contact area also scraped clean (does not have to be the same bolt as the cable). The only high battery current is for the starter motor which grounds directly to the case so you want the battery negative cable to go to the case and avoid an extra frame-case connection.
Frame connection will work OK but you have an extra connection to cause problems.
The stock cable is over spec for the actual starter current and that gauge is adequate for an extended length to a relocated battery, unless you put your battery in a trailer. Be very careful with the positive cable, add sleeving where it contacts the frame. If the insulation wears through from vibration (the heavy cable will vibrate and flex as you ride) and the core touches the frame ... very exciting, not in a good way.
Offline Register
« Reply #4 on: April 14, 2020, 06:27:01 AM »
Thanks, everything I needed.
I’ll save the trailer for the next build.
