Author Topic: SOLVED Newbie Intro and Throttle Issues--Revving out of control  (Read 2779 times)
Offline cheeseman
Hi Everyone:
This is my first post. First let me thank all contributors as I've perused these forums several times and the information is excellent!
I have had a '76 CB550 for about 20 years and have enjoyed riding it here and there, but nothing too serious. It really has no modifications and has always been reliable.  Most of my riding has been on the backroads around my farm in Wisconsin.
So last year I decide I want to take a trip with the bike, so I better finally get a motorcycle license!  It was an all day affair offered at a local Army base, and I learned a lot.  It was super chill as most of the riders were experienced, and we had a fun day on our own bikes--I of course had my 550 which the harley riders scoffed at, but seemed to take interest in the nonetheless!  The bike had performed well all day, and now it was time for the final road test.  About halfway through the test, out of complete nowhere, and at low speed (probly 2nd gear), the bike just screams and the rpms max out on the tachometer. Luckily my kill switch works and I shut it off. I I check the throttle cable and it seems fine, and I don't see anything unusual around the carbs. I start it back up and it screams up again. As I'm in the middle of a road test, I have no time for further diagnosis. What a time for the 550's first issue! Luckily one gentleman on a yamaha offered to let me use his bike to complete the test, so I earned my license.
I suspect something carb-related, but I haven't had time to pull them out and open them up yet.  Would you guys agree the issue is inside the carbs, and if so what should I be looking for?  And take not this wasn't just a high idlle. This is totally out of control engine screaming and tachometer immediately maxed out.
Also, after this incident, the bike is leaking oil while sitting. Seems to be weeping out of fins.  I haven't looked closely enough to see which fins/how high the leak is, but I know its not good. Would we suspect these things are related, and how so?  Head gasket maybe?  Would out of control rpm's blow a head gasket?  I was able to shut the bike off within 10 seconds, but maybe some damage already done?
Thanks and any suggestions would be most appreciated. I will post some pics when I get the bike out of cold storage.
« Last Edit: April 20, 2020, 06:16:50 PM by cheeseman »
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
Re: Newbie Intro and Issues
« Reply #1 on: April 13, 2020, 06:33:01 AM »
To scream like that something has to be wrong with the cables, take tank off and check properly that neither cable has anything wrong.
After that we will talk about oil leak
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: April 13, 2020, 08:13:08 AM »
The only possible explanation for the bike all of a sudden revving up and not stopping is a cable issue. Everything is mechanical and the bike can only rev higher if the carbs are opened with the throttle. The carbs have a pretty stiff return spring, so even a broken open cable wouldn't cause it to randomly gain rev's.
Offline pjlogue
« Reply #3 on: April 13, 2020, 12:38:09 PM »
You may have a frayed throttle cable which prevents it from coming back to idle.  Can't see it revving on its own.  You should check the linkage at the carbs to be sure it's free of anything that might get caught in it and also check your cables by unhooking them at the carbs and then gently working them.  They should be smooth as glass when you twist the throttle and not have any scratchy feel nor should the cable ends hesitate to extend when you push them out via a throttle twist.
Great you got your license!
-P.
Offline cheeseman
« Reply #4 on: April 13, 2020, 01:18:44 PM »
Thank you all for the responses. I will take the tank off and give the cables a good looking over.
Do you think the crazy revving could have broken something loose creating the old leak, or would you suspect they are unrelated?
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
« Reply #5 on: April 13, 2020, 01:37:16 PM »
Leaking oil is probably coincidental but these bikes have always been known for an oil weep at the sides of the heads, its possible a seal has gone somewhere.
1st get the throttle sorted
2nd clean off the engine thoroughly
3rd check exactly where oil is comming from
I have been working onthese since the early 70's and some things are more common than others, pottering arround at lowish speeds for 20 yrs can do more wear damage than highway but nothing major.
Offline cheeseman
Re: SOLVED Newbie Intro and Throttle Issues--Revving out of control
« Reply #6 on: April 20, 2020, 06:21:15 PM »
Thanks again for all your replies.
You were exactly right about throttle cables. The lower one (push I believe) had actually jumped out of the retaining bracket down by the carb, which allowed the whole linkage to wrench the throttle wide open. I guess the nut somehow backed off and out she popped.
And the oil issue.  Well I checked the oil level and it was actually above normal on the dipstick.  So I'm guessing this dipstick at some point overfilled the oil, and then there must be some sort of overflow where it leaked out.  Its not leaking anymore.
When I fired it up and adjusted the idle a bit it ran like a top.  As much as I love ripping up the trails on my DR650, it sort of feels/sounds like I'm riding on an air compressor.  This little 550 just sounds like magic.
Thanks again everyone!
« Last Edit: April 20, 2020, 06:22:59 PM by cheeseman »
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
« Reply #7 on: April 21, 2020, 12:12:39 AM »
There ya go, easy simple fix
« Reply #8 on: April 21, 2020, 06:40:13 AM »
The overfill of oil and leaking could be gas that has siphoned into the cylinders and past the rings from stuck float valve(s), piece of gunk/rust in the float valves. Does the oil smell of gas? If so, you need to rebuild the carbs. Do a proper cleaning of full strip down and deep soak, boil clean or ultrasonic clean and new Honda float valves and gasket sets or K&L carb kits.
Offline cheeseman
« Reply #9 on: April 21, 2020, 05:08:18 PM »
So you mean gas can actually leak into the oil and end up in the oil system and raise the oil level to the point it could leak out?
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
Offline cheeseman
« Reply #10 on: April 21, 2020, 06:34:32 PM »
I just thought of something. Last time I was using this bike my knee was bad and I couldn't engage the center stand. Instead it was always on side stand, making the bike lean. I bet I brain farted, checked the oil while bike was tilted, saw low on dipstick and added way too much oil.  Is that possible?
Oil does not smell like gas, although I have to shut off gas valve or gas will leak out overflows when parked--is that bad float valve/needle?
Thanks!
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
« Reply #11 on: April 22, 2020, 12:21:54 AM »
Yes to both.
To be safe might be worth an oil and filter change. It is supposed to be done every 1500 miles or yearly
Offline cheeseman
« Reply #12 on: April 22, 2020, 04:29:11 AM »
Great thanks!  I will change oil/filter
For needle/seat, do you recommend changing every needle and every seat, or just the ones that are overflowing or is there some evidence I am looking for?
From my limited experience, I have changed needles when they show some scarring or pitting or a ring around the tip. Have never changed a seat because they always looked good, but I guess I don't know the what constitutes good/bad in a seat.
I admit this is not a job I look forward to, as I don't like removing the carbs. I am always afraid I am going to tear one of those boots and it feels really aggressive yanking them out. If anyone has a trick/tip I would appreciate it. I know I tilt them a bit and rock them.  I think the first time I ever removed them I had to use a ratchet strap or something. Many years ago.
Thanks!
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
« Reply #13 on: April 22, 2020, 08:43:13 AM »
If its an outside carb and you can get the float bowl off you can change a float needle an seat in situ, awkward but it can be done
Offline ckahleer
« Reply #14 on: April 22, 2020, 09:18:57 AM »
I added a vacuum shut off valve to my V65 Magna to correct the same problem. 8 years later its still working fine.
Or you could install a vacuum petcock.
Float valves are for regulating fuel height. While they will work as a fuel shut off 99% of the time, that 1% will get you.
« Reply #15 on: April 22, 2020, 09:25:14 AM »
As an aside, when you change the oil filter first thing over the bolt is a spring, then a shim washer to protect the rubber seal on the filter frequently missing as it gets stuck to the filter and thrown away, if its missing dont sweat it just order one for next change
Offline cheeseman
« Reply #16 on: April 22, 2020, 01:33:13 PM »
Thanks Bryan, great reminder on that washer.
My Honda Rubicon ATV has the exact same setup, but it reminds you of the mistake by leaking!  Lucky I hadn't thrown the trash out!
So for the carbs, would you recommend changing just the needle or always needle/seat combo, and should I do it on all carbs?
Any recs on where to source a quality needle/seat?  The prices were all over the map on ebay.
Anyone ever tried rubber tipped needles?
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
« Reply #17 on: April 22, 2020, 02:00:03 PM »
Original Honda probably the best and to change the seat is only 1 extra screw. If you dont want to go original there is a firm called siriusonic in Canada and to me if only one outer leaks and you can get at it i would just do that one, if its an inner or you have to remove the carbs i would change all 4 and the fuel pipe at the same time, 5.5mm id by the way and not the see through reinforced crap
Offline Maraakate
« Reply #18 on: April 22, 2020, 07:15:21 PM »
I have a 77 CB550K and I can tell you from personal experience don't bother with the aftermarket needles.  Yes, it sucks spending ~$80 for OEM needles (you need four), but the time saved in constant headaches of trying to get the aftermarket junk to kinda/sorta/maybe work OK made it worthwhile.
Get a digital micrometer (any cheapy harbor freight special will do) and set the float height accordingly.
1977 CB550K
1979 CM400A
Offline cheeseman
« Reply #19 on: April 23, 2020, 05:13:34 AM »
Has anyone had any luck with 4into1 or K&L for carb parts?
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
Offline cheeseman
« Reply #20 on: May 02, 2020, 07:37:42 AM »
So I'll answer my own question. Don't use 4 into 1. Cheap stuff.  Replaced the seats and needles as 3 carbs were overflowing when parked.
Well first the seats did not want to seat.  I had to put some oil on the o ring and then really had force it in to get the o ring in place, whereas the old seats slid in nicely. I didn't like that, so I thought I could use the new needles with old seat.  Nope, new needle was too big for original seat.  So I got them in place, adjusted float height to 22, and also replaced the main jets as they looked a bit rough. These slid into place better.
As usual, pain getting the carbs back in.  So it fired up ok, but clearly is not running right.  Less power, a weird sort of puffing sound from one exhaust, and the idle is wacky.  It will go up, then down, even stalled out once. I guess I should have been content with just shutting the fuel off, as it was running great before.  But everything else was excellent, and I wanted it to be perfect!  Lesson learned.
So, can anyone recommend a better supplier for more needles and seats?  Thank. you!
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
« Reply #21 on: May 02, 2020, 08:25:14 AM »
Check one of my previous answers
Offline cheeseman
« Reply #22 on: May 02, 2020, 07:45:35 PM »
Ah yes, thank you I will check those out.
What is really weird is that one of the exhaust pipes isn't even getting hot...
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
Offline cheeseman
« Reply #23 on: May 03, 2020, 08:46:04 PM »
Any ideas on why the one exhaust pipe is cold?  Does that mean that cylinder is not working at all (it was before I messed with carbs). If so, would it be because the "new" main jet or needle/seat is not functioning?
Thanks for any input.
1976 Honda CB550F
2006 Suzuki DR650
1977 Jawa Babetta
1987 Honda Elite
« Reply #24 on: May 04, 2020, 04:13:42 AM »
Check ignition first: spark plug and plugcap OK and well connected? Any arcing between HT lead and/or plugcap and the head? This is best seen in the dark.
