Author Topic: 4 Cell Antigravity Battery  (Read 405 times)
Offline Peekster
  • you are probably underestimating me
« on: April 15, 2020, 10:19:10 PM »
Im in the process of replacing all the electronics and wiring in my 1974 CB550, Ill be using a Ricks regulator/rectifier combo and a m-unit blue. I plan to ride my bike to and from work at least 3x a week and cruise probably once a week. Is it possible to use only a 4 cell? Ill be kick starting as much as possible and keep a close eye in the charge level before using. Whats your thoughts on a 4  cell instead of the 8 cell? Dos and donts? Has anyone ran 2 4cells parallel to maintain the flatness of the 4 cell?
1974 CB550
Modifying custom parts
Offline jakec
Re: 4 Cell Antigravity Battery
« Reply #1 on: April 16, 2020, 11:24:42 AM »
my roommate ran a 4 cell and his bike had a 1v parasitic drain, destroyed the battery in a couple weeks. You would want to make sure the wiring and charging system was pristine because there's not a lot of room for error before you irreparably drain the battery.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Deltarider
« Reply #2 on: April 16, 2020, 11:45:14 AM »
Im in the process of replacing all the electronics...
Why? Anything broken?
Dos and donts?
Donts: IMO all things you mentioned. What a waste of money.
Things in the electric domain that had to be renewed on mine since it left the assembly line in 1976, apart from batteries and a few bulbs: NONE.
CB500K2-ED Excel black
Offline Peekster
« Reply #3 on: April 16, 2020, 08:02:03 PM »
Dos and donts?
Well The spaghetti bowl behind the head light got chopped up installing new handle bars and i want the simplicity of a M-Unit
1974 CB550
« Reply #4 on: April 16, 2020, 08:20:06 PM »
Don't expect the four-cell AG battery to run the electric starter; kick only. Also, you will need the Lithium specific Rick's reg/rect, as the Antigravity lithium-ion batteries are prone to melt-down if overcharged. :o
